Yikes!! What would you do to save the tractor from getting smashed?!
/ Yikes!! What would you do to save the tractor from getting smashed?! #122
^^^^^ yep.
/ Yikes!! What would you do to save the tractor from getting smashed?! #123
Old Gray Mare:
for my 2 cents-
Either I missed it or you never mentioned if the snow on the roof had melted. I would agree that quite possibly the snow melted, and what spring was left in the roof, let it rise up enough for you to back the tractor out. As for the tires...I also believe, unless you have seen or noticed 'a brine leak' on the tire, that the tire is fine. Even with the brine loading, you must still keep them inflated to required pressure. As previously stated, move tractor so that valve stem is at the very top, and fill tire to recommended pressure. Keep an eye on it, and if no brine is seen leaking, you should be okay. As you have stated, nearest tractor dealer is 75 miles away....where is the nearest tractor tire shop? They are the ones with the expertise, equipment, etc to repair/replace a bad tractor tire.
Also, living in the north east, we experience temperature changes all the time in tire pressures. It is very common. We went from a really quite warm 'fall' to a relatively cold 'winter' just recently. My wife's recently installed snow tires all had to be inflated again to pressure due the drastic temperature drop....I am talking 8 pounds per tire. The same holds true for summer tires installed in early spring....as temps warm up, inflation pressure has to be dropped or they will be overinflated. I am not sure about your location in Arizona, but you must notice a difference on you pickup truck tires from winter when temps are in the 30-60 range and summer when temps hover in the upper 80's to over 100.
/ Yikes!! What would you do to save the tractor from getting smashed?! #124
I was GOING TO read through the whole thread and post again with a suggestion that was forming in my mind.
I got to the DONE IT post, so CONGRATS !
Given that tools and resources are limited (Sure, it would be nice to get a Lull out there, but)
and as a mental exercise I had come up with;
Tack together an A frame type tripod on each side, this needs to be high enough to lift the roof TO.
Attach a pulley at the peak of each.
Run a rope under the roof, through the pulleys and down to 55 gallon drums.
Pull it short enough to get the drums far enough off the ground that when they get down to
the ground the roof will be lifted "enough".
Get the hose out, add water to each side maybe 2 or 3 gallons at a time - you might be able to bias
it as the roof rises - you might NEED to bias it one way or the other.
Be ready to STOP adding water, I suggest as soon as you see daylight between the ROPS and the roof.
Drive it out.
/ Yikes!! What would you do to save the tractor from getting smashed?! #125
One should always do that before replying.
I disagree, MOST of the replies are senseless drivel about getting equipment in, equipment
that isn't available.
The "Ya need a man around the place" tangent was entirely inappropriate, some would say insulting.
I didn't need to wade through all that before replying.
/ Yikes!! What would you do to save the tractor from getting smashed?! #126
There are also some very good suggestions. At the very least he would have found that the OP had already backed her tractor out, rendering his comment obsolete.
/ Yikes!! What would you do to save the tractor from getting smashed?! #127
Well sure Reg . . . but certain elements of the conversation can be lost . . . ;)
Thanks again for all the replies/help/suggestions. Some interesting reading for sure :)
Here are more pics since the snow is gone. They're before I backed out the tractor...taken as I was gaining courage to do so. Regarding the tires, both the ones on the left (they were bearing the weight of the roof) are low/flat. The ones on the right are fine. I've never had to adjust the pressure in either in Idaho or here.
The nearest tractor tire repair shop is nearly 75 miles away in Flagstaff. I have no way to get a huge-o tire into my truck :eek: There was an old guy who made house calls...this was 9 years ago...but he has since died.
Take a look at the pics. See how much the whole dang thing is ready to topple over :eek:
~~Judy
/ Yikes!! What would you do to save the tractor from getting smashed?! #129
I still would pump them up as suggested. You have nothing to lose, and there's no way you can get that loaded rear tire without something to lift it.
Looking at that picture of your rear, I still concur with others that it's just lost a little air over time. That's to be expected, I had to put air in the front tires of my 4 year old tractor this summer.
/ Yikes!! What would you do to save the tractor from getting smashed?! #130
Like the Man 'splaining ?
Like "get yerself a man" ?
It SEEMED urgent,
I replied pretty soon after reading the first couple of posts that were (as happens in SO MANY thread)
taking the thread downhill.
I wanted to warn Judy against getting hurt, doing damage, invalidating her policy - BEFORE - I waded through
those "(UN)certain elements".
I eventually got to them, most were what I expected - worthless drivel.
/ Yikes!! What would you do to save the tractor from getting smashed?! #132
/ Yikes!! What would you do to save the tractor from getting smashed?! #133
Well can we get this back on track a bit, maybe.
Old Grey Mare,
You are concerned with your tire inflation pressures and the possibility of a calcium leak.
I do not know what you have for an air compressor or tire gauges.
As has been mentioned to check the air pressure and even to add air your tire valve stems should be at the 12 o'clock position.
You should give the tire a shot of air before measuring the pressure, to clear the calcium out of the valve stem.
If you use a gauge be aware that you should have a low pressure gauge as your tires likely have a MAXIMUM pressure of around 25#.
This MAXIMUM pressure is NOT the recommended operating pressure.
It does not hurt to have a bit of a sidewall bulge on your tires, especially the rears.
Ifr you do a lot of bucket work with heavy loads you can run your fronts close to the maximum pressure.
The rears should have full ground contact with at least one and preferably 2 or 3 sets of tire lugs.
I only run around 13# in the rears on my Branson and my IH.
A couple of the larger farm tractors we do run 20#s in to reduce the sidehill roll of those tall radials.
Also if you get any calcium in your gauge you can try and draw some water in and out of it to rinse it,
but you will most likely end up needing a new gauge.
I very seldom use a gauge on a rear tractor tire, I almost always use one on implement and truck and car tires.
Glad you got your tractor out with no issues,
stay safe and enjoy.
Lou
I wanted to add this if you do have a leak in those tires, call around there should be a mobile tire repair outfit that makes house calls.
Or have your tractor trucked to a tire shop, you should not attempt to remove a liquid filled tire.
Yes, it is expensive to have a tire truck come to you.
/ Yikes!! What would you do to save the tractor from getting smashed?! #134
/ Yikes!! What would you do to save the tractor from getting smashed?! #135
...I wish the people here were like those in Idaho, but they're not. For example, I had a load of hay delivered and a bale fell off onto the dirt road. 30 minutes later they guys went to retrieve it and it was gone/stolen! In Idaho someone would have moved it to the side or even brought it to my place. Big difference in neighborliness :thumbdown:
OP is from Ash Fork and this is some sad news for a older couple from there.
Elderly couple found dead buried under snow, police say - CNN
Lets take thread on another tangent.
Interesting (or telling) quote from the article: "Other residents in the area had seen the couple's abandoned car for about a week and wondered why it had not yet been towed, Haas said. " -They didn't wonder: "Why is this elderly couple's car abandoned here after the storm? Are they ok? Has anybody seen them? Any other tracks or lights at their house? Nope! They wondered "Why hasn't it been towed away yet!? Somebody move that car!"
I hate having to inform you of this Judy, but your neighbors are ***holes!
(Don't marry any of them! :rolleyes: )
/ Yikes!! What would you do to save the tractor from getting smashed?! #136
Tires with ballast are more prone to changes in temps because they have much less air in them. That is why we all have to adjust front tire pressure more than the large rear tires, because they have less air capacity. I think the ROPs on the tractor would have been severely compromised long before the rear tire was damaged.
LikeI said...they people here are NOT neighborly. I can't imagine myself driving by an abandoned car for a week and seeing what looked like a dead animal.
At least notice the empty home or barking dogs or something wrong!
I'm still waiting for SF to return my phone-tag calls. This rep sure isn't in any hurry :thumbsdown:
~~Judy
PS...I don't plan on marrying anyone from here or anywhere. Been there, done that!!
/ Yikes!! What would you do to save the tractor from getting smashed?! #138
Hey there "judy"
So glad the MF is out of trouble. You definitely take good care of it as evidenced by the photos of it and your truck. Photos of rear tire do not indicate a brine leak. Get the tire pumped up and it should be good to go. Rotate it so that the valve stem is at the top, and as others pointed out...let a little air pressure out first to 'bleed' brine from the valve stem before adding air. As for the shed: photos show that it was clearly only built as a sun/rain shelter. No real thought was put into it for any type of loading. If you were interested in saving/resurrecting it, I would strongly suggest getting some competent help...possibly someone known from a local building supply or the like. However, do not do anything to it until advised by your insurance adjuster...not knowing your deductible, it may be a moot point. Best of wishes and enjoy your horses, tractor, and truck.
/ Yikes!! What would you do to save the tractor from getting smashed?! #139
If the insurance comes through I would recommend a metal building or carport.
/ Yikes!! What would you do to save the tractor from getting smashed?! #140
~~Judy
a single, older person, whose kids are far away should move to a friendly area, where you are now, the neighbors don't care about you, you may need to cry out for help sometime, and just die in pain, because your neighbors don't care!.. maybe people in hot climates get weird, since I've never heard of unfriendly neighbors on the northeast coast!..
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2019 GALYEAN...
MMS MS750 Remote Control Lawn Mower (A60463)
MMS MS750 Remote...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
