10 hour grease job question
   / 10 hour grease job question #21
In like the ridged pipe grease gun and loc-n-lube for my FEL and most joints.
This thread is inducing me to look for a system to grease by truck. Underneath the truck and difficult to hold on to fitting and pump at the same time. Almost impossible.
   / 10 hour grease job question #22
I don’t know why you’d want a lock&lube with a battery powered gun. The whole point was to free up your second hand to pump. In any case they don’t get along good with my backhoe. A Dewalt cordless and stock coupling for me. It’s actually a better than average coupler. I’ve never had it fail to work on a grease fitting that’s not damaged.
That’s not the whole point for me... Or how locknlube advertises their product. From their website:
Locks on, does not leak (true)
Grease goes in, not on, the machine (true)
Hands free, does not leak under pressure (true)
Easily releases from clogged grease fittings, even under pressure (true)
Have you actually used one? Freeing up a hand is a minimal benefit compared to everything else they do well.
   / 10 hour grease job question #23
Regardless what type of grease gun you use, you should grease a brand new machine. Yes, as soon as you get it. Most of the time new machines have never been greased or the grease cavities have not been filled. After that is done, I only grease equipment as needed. If it gets used more....it gets greased more.
   / 10 hour grease job question #25
If you hold it on I’ve never had a single one of those problems. I’ve actually never had a single one of those problems with the regular coupler on my Dewalt gun.
   / 10 hour grease job question #26
This is sometimes true, but it was pretty obvious on my machine that the dealer had greased the heck out of it. But yes, if the grease cavities are not oozing, you’re way past time to grease.
   / 10 hour grease job question #27
I bought one. Pumped several tubes of grease thru it. Mailed it to Murph.
I list all of your scenarios as false.
   / 10 hour grease job question #28
Me neither.
   / 10 hour grease job question #29
I don’t even know what this means. If you don’t like the locknlube, fine. Makes no difference to me. But it has solved a lot of problems for me and I’ve been very happy with it. I’m happy for you that you have never experienced any issues with grease fittings. Now have a nice day.
   / 10 hour grease job question #30
Rather than copy/paste each of your examples and address them individually I took the lazy route. Sorry if that offended you. Wasn't the intent.
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
