Talk to me about the rear remote hydraulic valve type...mx5200
   / Talk to me about the rear remote hydraulic valve type...mx5200
Yeah $337 cylinder and hoses delivered, everything went together super easy no bs.
   / Talk to me about the rear remote hydraulic valve type...mx5200 #32
Looking good. Easy now that it's done.
So I've been very happy with all aspects of this toplink setup but I just learned a lesson the hard way. I checked for interference but the hoses can still push the cylinder over enough that if it's mounted in the bottom hole on the tractor side and fully retracted, this can happen:
The raised boss of the cylinder contacted the cylinder mount on tractor. I now have the cylinder in the middle hole where this contact can't happen.
   / Talk to me about the rear remote hydraulic valve type...mx5200 #34
You can always flip it around and put the rod end on the tractor side.
Naw this is actually a 2/1 cylinder where the eye is 1.75" on the tractor end and 2" on the implement end. The tractor won't accept 2" width eye.
Industrias America 10F Pull Type 10ft. Box Blade (A50860)
Industrias America...
2012 IC Corporation PB105 School Bus (A48081)
2012 IC...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2007 Toyota Tundra 4WD Pickup Truck (A50860)
2007 Toyota Tundra...
