JD wheele on a Mahindra
/ JD wheele on a Mahindra #1
Spentit
Peyton Place NH
Mahindra 2565 with hoe, Case 530 back hoe, Hyundai180 LC-3 excavator. Love my Hoe's!
I have a 2565 Mahindra with R1 tires. Looking for R4 tires so as to be a bit easier on my lawn. Found a set off of a JD 4044R 6 lug front, 8 lug rear. I understand the matched gear ratio on 4x4 's have to have certain ratio's but my question is are compact/utility tractor wheels created equal across brands. 6 lug fit an 6 LUG, 8 lug fit an 8 lug? I want to swap these JD R4 10-16.5 front, 16.9x24 rear. Onto my Mahindra 2565. If it had R4's they would be 10.6/80x18 front, 18.4x24 rear. I researched the diameters on all the tires and the JD's are a bit shorter. Does any one have experience doing this? The JD tires are a bit shorter but they came off the same tractor so I am hoping for an equal rolling ratio. If that ratio matches the mahindra is the $5000. question, or what ever it cost to replace the gears that might get cooked. But at this point I am curious about wheel swapping. Any help would be appreciated.
/ JD wheele on a Mahindra #2
I don't reckon that there wouldn't be any problem as long as the lugs match up. Tractors, after all, go by hours accumulated as opposed to kms/miles travelled.
It shouldn't be a problem and you're not going to 'cook' anything as tractors don't travel fast enough to do that.
Thank you sir, I needed a bit of encouragement on this swap.
/ JD wheele on a Mahindra #4
There are no standard bolt circles, so measure carefully. Note also that some wheels index off of the hub hole, so that will also need to be the same. Otherwise, you can either only use two-wheel-drive, or you can measure the rolling circumferences and see if the ratio is correct. There exists a standard for relative tire sizes, so that if you use an A and a C, you could also use a B and a D, but it's not yet in wide use.
Thank you for the reply. The ratio calculation is my weak link. The tires are a matched set so the rolling ratio between them is a given I would think. But other variables come into affect. Like the front to rear ratio's on the donor tractor verses the front to rear ratio's on my tractor. Another comment posted earlier is that the slow speeds of a tractor would have little affect. And it would only be an issue when in 4wd. Maybe I am putting to much into this rolling ratio thing but it has to be addressed. Thanks again
/ JD wheele on a Mahindra #6
It will only matter in four wheel drive, but the speed doesn't matter: when on grass, you can drag or overrun the axle with least traction, causing turf damage. When on hard surfaces, the gears must absorb the difference in order to allow one axle to slip rather than binding. If it does not, such as on pavement, you can destroy expensive parts.
Easy enough to measure your own rolling tire circumference ratio, and possible to measure the replacement tires and get a handle on whether they are close.
Here are the numbers... Donor tires circumference : front 91", rear 153". Tires being replaced: front 109", rear 160". The question would be are the ratios's per revolution close. I can't do the math.....Anyone?
Sometimes I surprise myself. Please correct me if I am wrong. I got that the donor tires have a 1.69 to 1 ratio. Where the existing tires have a 1.4 to 1 ratio. Are the ratio's close enough to work or will they put an undue strain on the drive train? In 4wd of coarse.
/ JD wheele on a Mahindra #9
I did the same calculation and came up with 1.69 and 1.46. Either way that seems like too much of a difference. It would be a lot like constantly try to turn on hard surfaces.
I sharpened my pencil and found that if I swap out the 10-16.5 front tires to a 12-16.5 tire with a 101" cir. I get to a 1.51 ratio. I think is an acceptable risk. Now if the wheels will fit. Thanks for y'all's help.
/ JD wheele on a Mahindra #11
If I recall Kubotas front tires run about 5% faster than the rears. So the ratio doesn't need to be perfect. They do that intentionally for improved steering performance. The slightly faster fronts will pull the tractor where they are pointed mitigating the better traction of the rears trying to keep things straight, more or less. Of course with some sacrifice for tire life.
That is a good sign. Makes sense as well. Thanks
/ JD wheele on a Mahindra #13
I've put Kubota rims on a JD before and you might find this thread helpful:
http://www.tractorbynet.com/forums/build-yourself/120848-redoing-wheels-wrong-bolt-pattern.html
As mentioned before, both the bolt pattern and center hole are important. I had to alter both to get the Kubota rims to fit. You need to get the tire ratios as close as possible. It's been a while, but I seem to remember that you need the rolling circumference for the specific tire. I don't think you can rely on the size designation.
/ JD wheele on a Mahindra #14
OK, I've done that very thing a number of times.
The really good way to compare ratios is not the manufacturer's specified circumference, but instead using a number called "loaded rolling circumference". It's an easy number to get and no math involved.
We know that the front to rear tire ratio on the Mahindra is correct to match the internal tractor's Front to Rear transmission ratio right because those tires you have on it now are the factory originals and they are working for you. (I hope)
There are two ways to get the loaded rolling circumference. If you know the tractor's weight and pressure in the tire you can call the manufacturer of that tire and get to their technical department. They know the rolling circumference of their own tires, and they know why you need to know it.
Or there's an easier way that you KNOW is right. Here's how:
Pick a nice day, take a can of thick house paint of some color, a long tape measure, pencil and notebook, and find yourself a stretch of straight dry concrete or asphalt roadway a few hundred feet long.
Put a blob of sticky wet paint on one of the rear tire treads on one side and do the same for one front tire on the other side.
Hop on and just drive slowly in a dead straight line down the road.
Get down and measure the average distance between the blobs of paint left by each tire. You may have to do this several times to get good paint splotchs left on the road.
The distance traveled between any two blobs of paint is the loaded rolling circumference of that tire. The measurement will probably vary, so measure half a dozen to get an average. Don't be too surprised to find that your average loaded rolling circumference is a little different from the manufacturer's listed circumference for that tire. That's ok because what you have now is the real number for your tractor. Save those notes.
You can find the tire ratio by dividing the average distance between front wheel blobs by the average distance between rear wheel blobs. That gives you a decimal that is less than one - which is handy because if you multiply that number by 100 it becomes the front to rear percentage ratio.
Now all you need to do is to find replacement tires with the same ratio or close. Try to stay within 5% or your original measured ratio.
good luck,
rScotty
/ JD wheele on a Mahindra #15
I just wrote on how to find the circumference number that you really want - the Loaded Rolling Circumference. I urge you to get that number. It can save expensive repairs and makes it easier to compare donor tires.
But if for some reason you can't do that, you can at least find out if the tires you are considering are anywhere close. We can do that as an example with the numbers you have posted:
Your tractor's tires now are 109" front and 160" rear. We divide the two numbers to get a front to rear ratio of 109/160 = .68 . Or you can divide Rear/Front and get 1.46.
The way I did it first, allows you to multiply by 100 by shifting the decimal place two places to the right and calling it a F/R percentage ratio of 68%.
The Donor tires are front 91 and rear 153. F/R is 91/153 = .59 or 59%. ( or you could divide Rear/Front and get 1.68.)
You are off by 10%, and that's a bit too much for the drivetrain. It is also going to be a ***** to shift out of 4wd on any high traction surface. Also I can see by those numbers that we are going in the wrong direction...with those donors it is going to end up being hard to steer and will plow the front end when turning. Darn.... but read on....
Because that's not the end of the story. When you do the paint blob measurement to get the real loaded rolling circumference it may come out closer. And that will tell us the real story.
rScotty
/ JD wheele on a Mahindra #16
Take this issue of correctly replicating the front to rear ratios very seriously. The mechanical damage that is possible will be very expensive.
It will happen that you forget to come out of 4WD before moving unto a hard surface.
If you are concerned with lawn damage, the mis-match from factory ratios will be tearing up your lawn.
A number of years ago companies like John Deere put a label on the seat back of their 4 WD tractors as it was such an important number.
The WSM manuals had this info
Dave M7040
/ JD wheele on a Mahindra #17
D-a-n-g...... 4+ hrs later; many threads read; several threads saved; a few replied in; and finally - just after midnight I find the equation and the real world data in one thread & clearly explained too. Okay. Now I'm done for the night.
/Subscribed
/ JD wheele on a Mahindra #18
/Subscribed
Concrats on being so determined, and thanks for posting that JD sticker. That's handy to have.
Reading through the sticker, I was glad they pointed out the importance of using "rolling circumference".
When looking up that info on a tire manufacturer's tech site, it may be called: "Loaded Rolling Circumference... same thing. They just put the "Loaded" into the dimension because tire shape & circumference changes significantly with tractor weight.
You may not be able to find rolling circumference on the tire manufacturer's site. Not all of them list it. And RC is one really tough value to calculate, but the good news is that anyone can measure it. In fact, anyone can measure it very accurately for their own specific tractor weight and used tire circumference. One way to do so is in message #14 above. I should add that RC measurement method in post #14 should be done in 2wd, NOT in 4wd.
JD's sticker points out that the other piece of information needed is the the front and rear internal axle ring/pinion gear ratios. Apparently JD posts those values on the tractor itself, but that's rarely true for other makes. Luckily, gear ratios are also something that can be measured on your own tractor.
Enjoy!
rScotty
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2011 FREIGHTLINER FLD120 FLATBED (A65643)
2011 FREIGHTLINER...
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
Pair of 380/85R34 Tires (A65640)
Pair of 380/85R34...
2012 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2012 MACLTT 150...
