Now I know what GC2300 users felt like when I signed on here after buying my GC2410..
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #1
cdaigle430
Maine
MF GC2410
Left out now that the 1700 series are out :)
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #2
As a GC17010TLB owner, I now know how GC2410 owners felt when they released the GC1725MB's
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #3
Honestly, after much research, I am satisfied with the 2410 for the price and the feature-set I got used just 6 months ago. Things like bolt-on backhoe bucket teeth and a body-mounted FEL joystick are not enough to produce envy. Both the FEL and BH seem less robust on the newer models. I see that there is an OEM mechanical thumb for the CB65, and I would go for that if I could, but I will just have the fun of designing and fabricating one for the CB05 instead. The BroTek (or any bolt-on with the big bracket) is too cumbersome.
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #4
BXpanded makes a clamp on one you could look at as well I believe
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #5
THe BXpanded one is only for the CB65. It has the bolt on hole in the boom/dipper knuckle which accommodates the MF and Bxpanded thumbs. The other one from them is also saddled with a large clamp-on bracket and only listed for use with the newer CB65.
I want that low OEM profile and am willing to weld on the mounts, which I will have to design and fabricate. I'm pretty sure the steel, even with the plasma-CNC table cut time will still be under $200.
   / Now I know what GC2300 users felt like when I signed on here after buying my GC2410.. #6
If you have the means to fabricate it then yes, it should be cheaper
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
