Key Ignition Problem
/ Key Ignition Problem #1
Pibster
Member
Brookfield, Nova Scotia
Kioti CK25
I am having trouble starting my CK25. I turn the key on and once the glow plug light goes out, the tractor starts normally but as soon as I release the key, it stalls. If I hold the key in the start position after starting for 5 or 10 seconds, the tractor will usually stay running once I release the key. I知 not sure if it痴 the glow plug or the switch. I have bumped the key with my knee several times since buying the tractor, not an ideal location. Has anyone else experienced this? Thanks for any help.
/ Key Ignition Problem #2
I haven't experienced it with a Koiti but I suspect the fuel shut off circuit from ignition switch(internal problem with switch). Replacing switch would solve that but I would make some tests before replacing switch. Running a jumper to fuel shut valve is where I'd start. If jumper keep's it running,you could use tractor with jumper until new switch arrives. Or a penny pincher might add a manually operated switch to jumper and call it fixed.
/ Key Ignition Problem #3
had a similar issue on the Mechron, what I figured water got into the inside, I sprayed some wd40 for a couple days at the same tome kept turning the switch, battery off, it works as it should now.
a new switch was over 100 dollars
/ Key Ignition Problem #4
Try spraying WD40 or electrical contact cleaner in the keyhole and work the key a few cycles. Consider doing this annually. This is a common problem, but not always in the stop solenoid contacts. Dirt and corrosion finds its way into the electrical part of the switch. You can replace the switch but the problem will return, eventually. So just try lubing it.
Current directly from the switch holds the stop solenoid in the run (retracted) position. Any interruption of this current (like dirt in the switch) will stop the engine.
/ Key Ignition Problem #5
I have a CK4010 with the factory cab, and gets no water or dust or debris inside the ignition. My neighbors Kioti is 4 years old and open to weather and elements, and his Ignition was not working correctly. We thought it maybe a worn key from so many years of use. Got a new key, same problem. He went to dealer to order a replacement ignition, and was told to first spray WD40 into his ignition, spray onto key and work both for 5 minutes to help lubricate his ignition. He did this, and each time he withdrew the key. You could see globs of dust/debris on his key. Everything works good now. However, he did order a new ignition on Ebay just in case.
/ Key Ignition Problem #8
The WD40 did the trick. I’ll oil every few months from now on. Thanks everyone.
I think you may find that silicone spray will work better and last longer than WD-40.
/ Key Ignition Problem #9
Maybe not. This is mainly a cleaning issue, not a lubrication issue. WD40 is mainly a light petro distillate that washes away the dust-grease paste that fouls the contacts. The switch is very simple (see here). It is just a metal disk with raised semicircular tracks that make and break contact with stationary contacts. The disk seems to be prone to corrosion and dust infiltrates the assembly.
/ Key Ignition Problem #10
WD 40 (I knew the factory rep) is a fish oil based product and as such is non corrosive.
WD stands for water displacement, trial 40.
In aviation I used it for all corrosion related troubles.
Every year I inject it into all my key slots and never have a problem.
On tractors and other key operated switches I also use it.
Key switches use a lube that over time (faster in open stations) simply dry up and WD dissolves and allows normal contact).
Hey, an aviation client insisted that we service his old C 310 AC so I delegated a technician to 'make and break' every contact and spray WD40 on a 'hope and prayer' approach.
Well that client flew IFR to Mexica and back on instruments without a problem.
And I am not attached in any way to WD40 company, Just a believer.
/ Key Ignition Problem #11
WD-40 does not contain fish oil, contrary to a popular myth, nor does it contain any silicone, kerosene, water, wax, graphite, chlorofluorocarbons or diesel. It is mainly 60% aliphatic hydrocarbon (Penetrating oil) and the remaining 40% (a water displacing solvent) remains a complete secret by its manufacturer.
/ Key Ignition Problem #12
WD 40 is NOT fish oil. It contains petro distillates and aiphalic hydrocarbons. Not a big deal except some folks think this stuff is OK to drink; its NOT.
/ Key Ignition Problem #13
WD 40 (I knew the factory rep) is a fish oil based product and as such is non corrosive.[snip]
Aha! That must have been the guy that started that rumor. :laughing:
/ Key Ignition Problem #14
I'VE HEARD FORM OTHER KIOTI OWNERS ABOUT KEY SWITCH PROBLEMS. I REPLACED THE SWITCH ON MINE AFTER HAVING SIMILAR PROBLEMS, AND ALSO HAD TO REPLACE THE SWITCH ON THE PTO. IF KIOTI IS HAVING PROBLEMS WITH THEIR SWITCHES, ---BAD SWITCHES OR DIRT GETTING IN THEM, THEY SHOULD ADDRESS THE PROBLEM. THESE MACHINES ARE MADE TO RUN IN DIRTY ENVIRONS.
/ Key Ignition Problem #15
The key switch issue has been going on since day one for my 2005 Dk45S. About every 2-3 years the key switch will act up.
/ Key Ignition Problem #16
I spray Fluid Film into my key switch annually and have had zero problems with her since I started to that 6 years ago.
/ Key Ignition Problem #17
I sprayed mine in 2012 with fluid film, and had zero problems since. So I guess about 7 years.
/ Key Ignition Problem #18
James and Looking4new, that's interesting about Fluid Film working in the switches. Out of curiosity, I looked at the FAQ on the Fluid Film website. It says that it is lanolin-based, contains no solvents, so will not dry out. But, because it remains wet, it will "attract an initial dusting" :confused: It is also electrically non-conductive, so if used on electrical connections, "make sure all electrical connections are made before applying Fluid Film".
FAQ | Fluid Film
Not sure it's the best product to spray into a Kioti ignition switch, given alternatives. :scratchchin:
/ Key Ignition Problem #19
FAQ | Fluid Film
It may not be, but it sure has worked. Of course the fact that I keep the switch and the tractor it is attached to inside a building all the time and not out in the weather may have something to do with it. Before I had the building and it was kept out in the rain is when the problem developed and the fluid film solved it. But now it is kept in the dry.
/ Key Ignition Problem #20
I had the switch problem today; the key switch seemed to have a "dead spot" between on and start. I could hear the stop solenoid cycle as I rotated the key (either direction) between ON and START. I tried Radio Shack electrical contact cleaner in the keyhole but that didn't seem to help. Then I switched to WD-40 which fixed the problem. The WD-40 seemed a lot wetter than the contact cleaner. Just another data point.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
378908 (A61166)
378908 (A61166)
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
