Price Check Slow loader dumping with CT122
/ Slow loader dumping with CT122 #1
lristau 01
Member
I need some advice on my loader bucket. It dumps fairly slow and curls back in at almost double the speed. I put new quick connects and also swapped the fitting with another setting and it is still slow to dump only.
Is that a bad hydraulic ram or hose possibly?
/ Slow loader dumping with CT122 #2
Might not help but try swapping the dump hose with the curl hose and see if the result is opposite. Instead of lever to right for dump it would then be lever to right for curl. Make any sense?
Maybe you have already done this, I didn't completely understand your post.
Hey Winston, thanks for the input I have tried this with the same results
/ Slow loader dumping with CT122 #4
New quick connects, same results with hoses swapped, that would indicate to me the problem has to be in the cylinders or lines, however, I am clueless as to why.:confused:
Yea, I don't fully understand hydraulics so it seems weird to me that it can work fine one way and not the other. I guess the seal let's fluid pass from one direction and not the other some how?
/ Slow loader dumping with CT122 #6
most cylinders will retract faster than extend, less volume of oil to fill the cylinder not sure if its twice as fast. rough numbers 2" diam. w / 1" rod 24" long 1/3 gal to extend, 1/4 gal to retract
Okay maybe it's just naturally slow.
Thanks
/ Slow loader dumping with CT122 #8
Thanks
Are you aware of and/or tired dump in Regen mode of joystick? If not, move joystick to right until it feels like hitting hitting end of stroke the push harder and it should move and you feel additional spring tension. The Regen mode shifts the valve spool further so oil from the rod end is directed to the oil going the to the base end of cylinder, mixes with gear pump flow for close to X2 flow into the cylinder.
No I was not aware of this feature. I will try it when I get home from work next week. Thank you for the advice!!
/ Slow loader dumping with CT122 #10
I went out and tried it on my CT235 and although I suppose I have pushed my lever all the way to the right I have never really been aware of that dump feature. Never to old to learn. Thanks, SSdoxie.
Would a 2008 ct122 come with that feature?
So it appears that mine doesn't have that feature. I never started the tractor but I tried pushing the lever to the max then going further and it just feels like I'm going break it off
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
2019 INTERNATIONAL LT625 DAY CAB (A60736)
2019 INTERNATIONAL...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
