Oil & Fuel 1540 front axle leak
   / 1540 front axle leak #1
ottawarob
Ottawa, Ontario
BCS, MF 1540
Plowing the driveway the other day, I noticed at the end of it, part of one of my front axles was oily. Took a look in the peep hole today, and I couldn't see oil in there, though viewing is really tight. Going to put some hydro oil in and see how much it takes to get it halfway up on the shaft. In the photo attached I've circled where it seems oily. At first I thought it might just be snow melting off of the hub during plowing, but I'm suspicious since the oil seems low. What seal have I probably blown?
   / 1540 front axle leak #2
There have been numerous posts about that seal (it's in the lower location on your pic) going/leaking on GC series tractors. Not too bad a job to replace it, from what I've read. Haven't had that issue with my GC2310... yet! Try search for "axle seal."
Thanks! Yeah, it looks pretty accessible. Sadly my workshop won't be built until next year, probably going to have to get someone to fix it. Really cold outside to be fixing machinery, and the gravel on my barn is a bit dangerous to jack a tractor up on. :/
   / 1540 front axle leak #4
Not a job I would look forward to. I have been praying mine are not leaking yet on my 1540 after seeing what is involved. I try to keep mud away from the joints but it is easier said than done.
Yeah, if I had my shop w/ a concrete pad set up I'd consider taking it on, but as is I think I'm going to send it in.
   / 1540 front axle leak #6
Its an easy fix. Drain the axle oil. Use a screw driver or something and punch a hole in the plug to remove it. Clean the area. Apply adhesive silicone to the outside of the new plug. Use a hammer and block of wood ad and drive the plug in until it is flush with the housing. Then use a socket as a driver and drive the new plug in so that it if fully seated into the housing (not flush with the housing).
2013 Bell B35D Articulated Dump Truck (A59213)
2013 Bell B35D...
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A56858)
2021 Chevrolet...
Dynapac CC122 Smooth Drum Roller (A57453)
Dynapac CC122...
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
2015 Nissan Frontier Pickup Truck (A56858)
2015 Nissan...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
