Build Your Own 3 Point Carry All
   / Build Your Own 3 Point Carry All #31
Dj54...now thats a carry all! I like that design.
   / Build Your Own 3 Point Carry All #32
Thanks, I pretty much copied the frame of a bale carrier I have, with some extra bracing to take the force of the cylinder, then added the dump bed on top. The original plan in my mind, was to make removable side boards, but it will carry enough dirt/stone as it is, that it's all the Ford 2000 will handle.
With the hydraulic top link used on it later, I can tilt it forward enough, that hauling fence posts, etc. it won't roll off. I used it more than several years ago to haul old fence posts, from a fence line I tore out. Pulled posts with the Bobcat, then loaded on the carry-all, then hauled and dumped them on a burn pile.
Back then, I had about $250 in steel, hydraulic lines, and fittings, and was worth every penny. It should last me a life time.
I built this about 15 years ago. Comes in handy for many jobs, from mucking stalls, and carrying to the compost pile, to hauling hay, firewood, dirt, stone, etc, etc.. At the other place, was handy when gathering rocks out of the field, and pasture. Then back up to a wash below the pond outlet, and dump.
A hydraulic dump carry all! Now that's cool!
   / Build Your Own 3 Point Carry All #35
Well all is done but some paint, think I will do some sort of red to make it stand out hahaha.
That’s looking good!
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
