Just thinking out loud here,
/ Just thinking out loud here, #1
Reb954
20 miles from somewhere.
Mahindra 2565
I wonder how effective a box blade would be with an SSQA attached to the backside so the box blade could be used (reversed) on the loader frame to move snow.
I have a few uses for a box blade but not enough to be worth buying one as a 3 point mount only. But I do get a lot of snow to move. If I were to setup a SSQA mount on the backside of the box blade for moving snow it might be more efficient/effective than using the bucket. I would still use my rear mounted snow blower for moving the bulk of the snow but in areas I can't use the blower, the box blade may be handy to have due to capturing the snow.
I am sure someone has already done this, if so, what was the results?
/ Just thinking out loud here, #2
Here's a land leveler done that way, don't recall the poster's name but I got 'em here on TBN - if I ever decide to build one, it'd have a LOT of these features... Steve
/ Just thinking out loud here, #3
I think you have a snow pusher in mind as the result of your modification. A box blade works in both dragging and pushing so you would need to be mindful of welding in a SSQA bracket and forfeiting part of the box blades function.
/ Just thinking out loud here, #4
I think it would clog full of snow pretty quick and be useless. Up to a couple feet of snow, you'd be better off with some kind of front mounted scraper blade you could angle to shove the snow to one side. Snow deeper than that, either stay with the bucket and snow blower.
/ Just thinking out loud here, #5
If you have box blade with the rear cutting edge ALSO could you not mount it backwards to push your snow and not capture snow it in the as you do dirt for moving it?
/ Just thinking out loud here, #6
I agree with the others. I do use a 3pt box blade for snow, along with a bucket on the FEL. The box blade fills up and just spills over the top, requiring more repeat passes. I'd go with either an angled front blade or a snow pusher instead. A good snow pusher will just keep rolling the snow back over in front of itself, and not spill over the top and fall under the tractor like a box blade will.
/ Just thinking out loud here, #7
The idea of having a land leveler or maybe a box blade on either end would be okay in some applications to move dirt. The so limited amount of carry ability to push the snow to where you want to deposit it would make it a futile effort at best with either of those items.
Moving snow requires the ability to carry or push it in larger quantities to the location you want to deposit it. The ability to roll it to one side in windrows ultimately moving it from a covered area to somewhere else is key if you have large areas to plow. As said above, larger snowfall amounts might require a loader or blower. I actually miss the job of plowing snow like I used to do. Living in the south does have some advantages but I do miss plowing snow.
/ Just thinking out loud here, #8
One issue with mounting on the loader is the difficulty in maintaining the height desired.
I didn't do it with a box blade but I did with a york rake, it was difficult to maintain the rakes height where I wanted it,
down pressure would really sink it in the grave or dirt then in just a moment it was 3-4 inches to high and dumping everything out.
All good things to think about.
What I am considering is making the box blade into a snow pusher but keeping it so I can also use it as a box blade. My bucket and tractor is 6 ft. wide so the box blade would need to be at least that width but I would prefer 7 ft. I am figuring the box blade capacity should be considerably more than the bucket so the end result is I should save a bit of time moving snow with the extra capacity.
My process is to move the snow out of the primary drive with the bucket. Some of that snow is stacked off to the side but some has to be stacked in a secondary driveway that goes to the barn. Once the primary driveway is clean, I turn around and use the blower to clear the snow that was stacked in the secondary drive, clear the rest of the secondary drive and clean around the barn. It all takes about an hour which includes warm up time for the tractor.
In reality it probably isn't worth the time and effort to adapt a box blade to do this but if I can find a used box blade at a reasonable price I may just do it anyway. I like projects.
/ Just thinking out loud here, #12
I guess once your ground freezes up hard, it may work ok. Until then, it's going to be difficult to use. Downpressure with FEL, or float? Getting the angle right between the "front" and "rear" blades on the box blade so it doesn't dig in too deep, or skim too high over the top. I try not to use my box blade much if I can help it, until the ground has frozen up hard as granite. Then with the box angle set to be just barely lower on the rear blade than the front. That way I can scrape hard if backing with it down, for peeling ice layers off of pavement, and I can still get the surface clean and dressed when pulling forward.
I've looked at snow pushers myself. If I ran snow removal jobs for a business, I'd probably get one. But at most, I'm doing mine and maybe a couple of other places, mostly as "favors" for friends and neighbors, so I can't really justify the expense.
Still getting a rear 3 pt snow blower though. Maybe this year. Lol.
/ Just thinking out loud here, #13
Don't move snow, but I saved this idea for pushing a box blade from Road Boss on a LPGS:
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
2011 Ford F-250 Knapheide Service Truck (A61568)
2011 Ford F-250...
2015 GMC Sierra 1500 SLT Crew Cab Pickup Truck (A61568)
2015 GMC Sierra...
2014 John Deere 6125R Tractor (A64047)
2014 John Deere...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
