Kioti LK3054 Alternator Generic Replacement
/ Kioti LK3054 Alternator Generic Replacement #1
retiredfarmer
Bloomington, IN
Oliver Super 55, Kioti CK35, NH TC25D, IH454G, IH464D, Ford 2000 3cyl D, Bobcat T590,
The direct alternator replacement for a Kioti LK3054 is the alternator for a 1979 Mazda B2000 truck. This alternator is a Mitsubishi and is identical down to the 4 pole pigtail plug. (You might need a shorter belt, however the belt on my tractor may have been plenty stretched due to it being an original 1997 belt.)
This alternator was $60 at O'Reilly Auto Parts, the parts store where the guy behind the counter figured out what would match.
RF
/ Kioti LK3054 Alternator Generic Replacement #2
Re: Kioti LK3054 Alternator 敵eneric Replacement
Thanks!!
Hopefully I added a photo.
RF
/ Kioti LK3054 Alternator Generic Replacement #4
Very interesting. Kioti OE alternators are quite expensive (like $500!!!).
Is this for a later model LK3054 (like G265- serial number?) If so, that alternator (Kioti #E7230-64012) will also fit many other Kioti models (like my DK45s) and I would recommend making this thread a sticky post. The older (F265- serial numbers) could have had one of several different (part number) alternators, including this E7230-64012. I cannot tell if this was just a part number change or if the alternators were really different.
I can not speak to the later models. The 3054 it did work on was a 1997 model.
RF
/ Kioti LK3054 Alternator Generic Replacement #6
Thanks for posting this!
My LK2554 stopped charging after several years of flashing. I went to my local parts house and bought a alternator for the 79 Mazda and it was the same except the pulley is a little smaller. Had to get a 40.5" belt to work.
I also had to get a new voltage regulator. I got one for a 1970 Toyota truck and it had the same plug and bolt pattern.
System is charging and no more flashing light! :cool2:
Good deal on the Voltage reg. I suspected it was the same when I was looking at it, but did not want to speculate. Thanks for trying it to see.
RF
So, the Toyota truck alt will work in addition to the Mazda truck alt?
RF
/ Kioti LK3054 Alternator Generic Replacement #9
depending on it's output, the original alternator can be replaced with a higher output alternator if needed. OE tractor alternators tend to be low output..
/ Kioti LK3054 Alternator Generic Replacement #10
RF
No Sir. The Toyota voltage regulator will replace the one from Kioti. I used the Mazda alternator.
/ Kioti LK3054 Alternator Generic Replacement #11
sub'd for hope to never need but just in case reference....!
/ Kioti LK3054 Alternator Generic Replacement #12
tractor alternators are not that heavy, in fact, a person can easily lift one with one hand!!.. no medium lift helicopters needed!!..
K5lwq; My apologies, I mis-read your post. Excellent find on the Toyota VR. I was suspecting the Mazda one would work, but it looked mechanical from the online pics I was referencing.
RF
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
203201 (A60429)
203201 (A60429)
208320 (A58375)
208320 (A58375)
2022 EZ-GO ELITE...
