bocat ct230 tractor oil leak
   / bocat ct230 tractor oil leak #1
randy0706
ct230
I also have a bobcat 230 with a mid point hydraulic leak I see where other owners have the same problem but do not see the fix I have it split but cannot tell where the leak is any help anybody
   / bocat ct230 tractor oil leak #3
What is the Kioti equivalent to these tractors?
I do not know what happened to WILLIS's leak. That post was 6 years ago with no update.
It really comes down to how fast is the leak? One drip per hour or 2: live with it. One drip per minute: fix it.
I have had both of these DaeDong M27 tractors, the Bobcat CT230 and the Kioti CK30.
   / bocat ct230 tractor oil leak #4
The OP has the tractor split so I think he is committed at this point. I normally look closely at leak evidence first, if that doesn't help, then I would use the spray foot power to locate seepage. Problem is the tractor is split, so the OP is asking where other's have had leaks. I hope pictures are coming....
I can get pictures I have not taken any yet the leak was only when the tractor is in use the warmer the hydraulic oil the more it leaks it needs fixed as soon as I get back to it I am going to take the hydro off and see if there are any leak signs on the back side the bottom shaft that goes to the front driveshaft looks dry
   / bocat ct230 tractor oil leak #6
I can get pictures I have not taken any yet the leak was only when the tractor is in use the warmer the hydraulic oil the more it leaks...
Yeah, pix!
Were any of the bolts a bit loose when you removed them? Esp the ones that hold the tunnel or gearbox together. Also, did they use a paper gasket, or some kind of sealant, or both?
ok we finally put the tractor back together today I do have pictures but my wife will have to post could not tell where the leak was coming from so we put new seals in lower shaft and new o rings on the back side of hydro and new o rings on all the interal lines got it all back together the hydraulics work fine but the hydrostat does nothing no movment feals like it needs primed or bleed out any body have any ideals
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
2014 Freightliner 105' Bucket Truck (A56436)
2014 Freightliner...
500BBL WHEELED...
Utility Cart (A59228)
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
