Apps for land survey - Property lines
/ Apps for land survey - Property lines #1
Junguda
Member
Tennessee
Kubota L3400 HST
Does anyone have experience with land survey apps...? I’ve read about “Theodolite”, but need a specific function... I’ve got two turn points, and need to walk between them and be able to tell when I cross that property line...
Uhhhh.... never mind.. I found the thread from 2018.... Apologies...
/ Apps for land survey - Property lines #3
could you direct us to that thread? i can't find it
thanks
So I installed “BaseMap” and walked out to the property line... it shows a green dot with arrow as I walk around and it’s within 10 ft of accuracy.... as I’m on the SE border of our town lot... plan to try it at the farm tomorrow...
/ Apps for land survey - Property lines #6
I commented on the other thread to but I am a land surveyor. I feel the need to comment on this one. There is nothing wrong with using an app like this if used for the right reasons. You wouldn’t want to use it to build anything, say a building or a fence. You might think you have 10 feet accuracy, but for a lot of reasons it might be worse than that.
Thanks Dodge Man.... as a surveyor, how much do you charge to explain the terms in a deed...?
/ Apps for land survey - Property lines #8
No disrespect meant to DodgeMan, but I believe you want a title attorney for the answers you are looking for. Unless you want somebody to actually look at your lines, then the D-Man is your man!
/ Apps for land survey - Property lines #9
Some attorneys are good at reading deeds but not many. I will interpret deeds for people and explain them if possible. It’s pretty rare anyone asks for it though, they usually want it surveyed to. Probably just a few hundred dollars to figure a deed out, if it’s simple I will often do it for free. I’m not licensed in Tennessee by the way.
No problem... Neighbor said he’d send me a copy of the survey he had done for the building site...should clear up the question.... but thanks for the info...!
/ Apps for land survey - Property lines #11
Dodge man - I am trying to locate some property corners. I have found one but not the other three. On the deed it lists distances and bearings. I understand how the quadrant bearings work but what is the north reference - geodetic, magnetic? I want to start at the known corner and navigate to the other three so I can see if I can find the monuments I just am unsure on getting the bearings right.
If I find the monuments and the distances and bearings jive with the deed I think I could feel pretty confident about it.
/ Apps for land survey - Property lines #12
I've looked at a few around me and none of them make those kinds of mentions. They're all ...
... from a large oak tree along a field formerly owned by Jimmy John meandering generally westward along the Willie Lou property ...
Problem is, few people alive today remember Jimmy John or Willie Lou.
/ Apps for land survey - Property lines #13
If your deed doesn’t call for monuments (pins, posts, or...) then the bearings and distances are what you follow. Deeds are generally written in magnetic bearings.
The most subjective that I’ve ever read was “ hence to the place where the old cow lays down in the afternoon.” My deed simply says “by the land of, by the land of, by the land of, then down the town road to the point of beginning, containing 21 acres more or less.”
There are pins on my easterly corners and another on my back line, and a fence around the west of it which everyone agrees is the division line. My permanent buildings are 400 feet from any lines so I’m not too concerned.
/ Apps for land survey - Property lines #14
This is what I have to work with:
BEGINNING at a railroad spike, set for the Southeast corner of Section 14, the Southeast and beginning corner of this tract;
THENCE North 0° 01' 20" West, , 376.00 feet to a railroad spike set for the Northeast corner of this tract;
THENCE West, at 60.00 feet pass a 1/2" iron rod, continuing for a total distance of 580.00 feet to a 1/2" iron rod set for the Northwest corner of this tract;
THENCE South 0° 01' 20" East, at 326.00 feet pass a 1/2" iron rod, continuing for a total distance of 376.00 feet to a railroad spike set for the Southwest corner of this tract;
THENCE East, 580.00 feet to the place of beginning.
All I can find is the 1/2" rod in the NW corner. According to this there should be 5 other monuments. If I can find all or most of them and the bearings and distances match I can feel pretty confident they are indeed the markers.
I am building a fence and want to be sure but I really don't want to spring for a survey unless absolutely necessary. If I can't verify the markers I have no choice but I should at least try to check it first.
/ Apps for land survey - Property lines #16
At very least, go to your local rental place and rent a REAL metal detector, something like this:
A big fabric or steel tape measure on a reel (at least 100' long) and a compass app on your phone should get you close enough to find the pins with the metal detector.
Aaron Z
/ Apps for land survey - Property lines #17
Aaron Z
I used to have a Schonstedt but don't anymore.
If I have the distance and bearing I have the tools to calculate and locate the point within an inch. I just am not sure on the bearing.
/ Apps for land survey - Property lines #18
North blah blah west means blah blah to the west of due north. You need to convert from degrees, minutes, seconds to decimal degrees to use on a compass. Though 0 degrees (due north) minus 1 minute 20 seconds is really close to due north. Probably well within the margin of error of a phone compass.
See Compass Questions
/ Apps for land survey - Property lines #19
I am not using a compass and I know how to do the conversions. It all means nothing though if you don't know the basis of the bearing. Grid north, magnetic north, Geodetic north, etc.
/ Apps for land survey - Property lines #20
For the last several years, I have put the basis of bearings on my plats, but a lot of times there is a phrase "bearing assumed for descriptive purpose only". Which really is just saying the bearings give you the angle between the corners. If I used GPS, the bearings are usually grid north. Other wise most likely magnetic north, but hard to say for sure. From what you wrote, it was almost surely surveyed. Do you have a plat?
Also when the deed says "60 feet pass a 1/2" rod", I would assume that means there is a rod on line, but at a 60 foot offset from the actual corner. I often set an offset if the actual corner is in a roadway, say set an offset at the back of ditch. I'm not sure about Texas, but Illinois has a monument recordation act. This means we are required to file a monument record for the section and 1/4 section corners. This would be at the courthouse.
Also is Texas a recording state? Illinois is not so at best maybe half of my surveys get recorded, but check at the courthouse to see if a survey exists for your property.
I'll just add unless you are using some kind of survey grade equipment, as you navigate to your next point, you might only get within about 20 feet of where it is. Take that into account when you look for them.
STORGE SPACE WITH MISC ITEMS (A67714)
STORGE SPACE WITH...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
213065 (A64276)
213065 (A64276)
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
