4052R - Operate PTO Off Tractor Seat??
   / 4052R - Operate PTO Off Tractor Seat?? #11
THANKS for the reply!
Just curious - how often do you use the tree puller on the 3PH instead of the FEL? I don't have the same puller that you do, but I'm considering modifying mine to fit on the 3PH for the extra lift capacity. (I have a 3520 with a 300CX loader)
Only a few times. I found it to be much more effective on the front end where I can use the curl function to work the tree loose. Also, many trees with bigger root balls need to be lifted fairly high.
I wish it worked better on the 3PH so I could use it at the same time as my Grapple.
2019 Komatsu WA380-8 Wheel Loader, S/N A74991, PIN# KMTWA130VJNA74991, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
