14.9-24 vs 17.5-24 tires
   / 14.9-24 vs 17.5-24 tires #1
4tillingdirt
nc
N/A
Given a choice on the same size tractor, which size would you choose?
   / 14.9-24 vs 17.5-24 tires #2
My choice of tire would probably depend on my intended use of the tire and the load capacity of that tire. You're not giving much info.
   / 14.9-24 vs 17.5-24 tires #3
The 17.5L are a tad shorter and wider. May offer more floatation in certain conditions. May technically produce more "torque" to the ground (by a very small margin) because of higher tire rotation speed in gear (likely so negligible that it won't be noticed) Will offer slightly slower travel speeds.
The 14.9 are a tad taller and narrower. May offer better traction by "digging in" due to too the narrower tread. Will offer slightly faster travel speeds.
Just using it around the house - plugging yard, sowing grass, mulching trees, scraping driveways
   / 14.9-24 vs 17.5-24 tires #5
Personally, I've never saw a tractor tire too wide.
Improves ride quality, adds stability. Go wide.
   / 14.9-24 vs 17.5-24 tires #6
   / 14.9-24 vs 17.5-24 tires #7
I want to get wider tires for my LS tractor because it seems like in the mud and when the ground is really wet my current tires just act a rototillars instead of tires. I am not sure where a good place is to find these or rims if I need to get wider rims. Anyone have any suggestions?
   / 14.9-24 vs 17.5-24 tires #8
If the tractor is 4WD,, the tire height must be correct,,
or else,, there will be more posts on why you can not get the tractor out of 4WD,,, :eek:
   / 14.9-24 vs 17.5-24 tires #9
What size tires are on it? What bolt pattern?
David from jax
   / 14.9-24 vs 17.5-24 tires #10
For my Allis Chalmers D-12, it already has the oversize tire option of 14.9-24. My John Deere 2555 has 14.9-24 on it, and i would go to the wider tire for it. However, i have a bunch of spare rims and tires, so buying rear tires probably isn't likely to happen.
David from jax
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
LANDHONOR LHR-PC90 HD PLATE COMPACTOR (A52708)
LANDHONOR LHR-PC90...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A57453)
New/Unused AGT...
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
