Floppy Bucket !
/ Floppy Bucket ! #1
TimP
Kingsville, MD
B3000HSDCC
Hi All.
I have B3000 with an LA403 FEL.
It's a pin on bucket.
It seems to me that the bucket is "Floppy" or sloppy.
There is a lot of play in the bucket movement on the pins.
Wen I rock/shake the Bucket to empty it, the bucket seems almost loose.
Is this normal for the LA403? I had a B2150 with a LA305 FEL it was tight with no slop.
Thanks!
/ Floppy Bucket ! #2
Make sure the pin on latches are securely latched. Sometimes dirt will get into the latches to prevent them from being fully secured.
/ Floppy Bucket ! #3
Are the pins worn?
/ Floppy Bucket !
Are the latches where the securing pins are located? One and the same?
/ Floppy Bucket !
Are the pins worn?
I have not given everything a real close inspection, but I may try to disassemble/remove the bucket and then rfeinstall it.
Maybe I can figure out if something is loose or worn.
The tractor had less than 300 hours on it when I bought it, but I think the previous owners used the FEL a lot.
The FEL is tweaked a little bit, so maybe the problem is related.
/ Floppy Bucket ! #6
At only 300 hours I would be surprised if you actually have slop from wear. I agree check all pins and re-seat them first.
/ Floppy Bucket !
Thanks everyone for the list of things to check.
I now have another thing to add to my weekend project list !
/ Floppy Bucket ! #8
Any pins that can be in dirt can get sloppy quick. This is why you grease them. Some floppyness is fine and can help clean out the bucket as you have seen.
/ Floppy Bucket ! #9
Could it be a glitch in your hydraulics? I've got a low hour backhoe with a 4 in 1 loader bucket. Sometimes the "jaw" of the bucket just flops open 3 or 4 inches. No biggie- just close it again and it stays closed for awhile. But it almost has to be hydraulics in my case.
/ Floppy Bucket !
It was greased up when I first bought it, but I don't know how often the previous owner did maintenance.
/ Floppy Bucket !
I guess it could. I'll go over the pins and see if I can spot any problems. Other than that, I'll have te dealer look a it when I send it up for my annual maintenance.
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2006 Ford Crown Victoria Sedan (A61569)
2006 Ford Crown...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
(2) Good Year 16.9-24 Rear Tractor Tires (Turf) (A61166)
(2) Good Year...
2023 John Deere 9RX 640 Track Tractor (A63109)
2023 John Deere...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
