1715 Rear Wheel Flip ?
/ 1715 Rear Wheel Flip ? #1
Dataway
Gold Member
Greenfield TN
Ford 1715, BX2200
Are the hubs in the rear wheels of a 1715 centered inside/outside? Just wondering if they can be flipped to pick up a few inches of width. Seems like some old school tractors you could do that.
Lug holes could be tapered .... not sure, I've never had one off.
/ 1715 Rear Wheel Flip ? #3
I believe the owners manual allows the rear wheels to be set out for stability but the front wheels are to remain in the factory narrow position. The front axle and bearings can sometimes carry the load of the entire tractor, ballast and fel should the bucket be loaded too heavily hence the prohibition.
/ 1715 Rear Wheel Flip ? #4
FWIW...If a tractor is on or was on a dealer's lot it is likely that the wheels have been narrowed up...
Yes sir you are correct, checked the owners manual and it says rear wheel tread width can be changed from 42.2" to 48.2" by reversing the tires (swapping sides I think that means) ... question is .... is mine already done .... I'll check tomorrow.
/ 1715 Rear Wheel Flip ? #6
Not swapping sides, just turn the tire around so the valve stem is on the inside.
/ 1715 Rear Wheel Flip ? #7
You need to swap sides and not turn inside out to get the tread facing the right direction for R1 and R4 tires. I assume you have R1 AG tires on a 1715. I do not think you can do the swap with turf tires since the wheel offset is so deep already.
/ 1715 Rear Wheel Flip ? #8
.... but the front wheels are to remain in the factory narrow position. The front axle and bearings can sometimes carry the load of the entire tractor, ballast and fel should the bucket be loaded too heavily hence the prohibition.
I heard this, but never "got it".
If a rim has a dished offset (or inset) that makes them narrower or wider, I don't see where the direction of the rim offset puts any less "lateral torque" on the bearing, it just puts this torque in the opposite direction.
That is: a deep rim offset set wide would want to pry the bottom of the bearing out, and push the top in; whereas if you flip the rim, the same offset now wants to pull the top of the bearing out, and push the bottom in.
The leverage distances, and forces are all the same, just reverse direction.
Is my thinking wrong?
Now if you're changing the offset distance by how the inner rim "dish" mounts to the outer rim, yes it would effect bearing loadings. .
/ 1715 Rear Wheel Flip ? #9
Correct, I was talking about turf tires which it sounds like the OP has.
I flipped my rear turf tires when I first got my 1510 as the manual said could be done.
I have the 11.2 x 24 AG tires .... measured them, 42" right now, yep I can swap sides and gain 6 inches of tread width ... can come in handy on my hilly property.
Also it will move the valve stems to the outside, real pain having them on the inside right now.
In a month or so it's going in my shop to get one of the rear rims replaced .... rusted out ... I'll be ordering a new rim and welding it to the old hub which will be fine after some painting.
/ 1715 Rear Wheel Flip ? #11
HI, MY 1715 HAS 12.4 X 24 ON THE And they are reversed. Also the front tires are 7-14 and also reversed. According to the owners manual this isn't right? Do I need to change both front and rear tires as well as the front wheels? I just bought this for a reasonable price cane with a loader and backhoe, back hoe needs a cylinder. Thanks for any incite I'm totally new at this. I think I'm in for one heck of a project?
/ 1715 Rear Wheel Flip ? #12
When you think about it, reversing the front tires really accomplishes little for stability since the front axle still pivots in the center. My tractor also had the front wheels reversed. I put them back to normal had have noticed no change in stabitlty.
Yep a wider stance on the front only helps stability when the front axle pivot hit's the limit stops .... which when you think about it might help in an emergency ... but wouldn't have any effect until the tractor was already in trouble.
Chestr ... I don't think you would need to change tires, you just move the left wheel to the right side and the right side to the left side.
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63118)
2019 Takeuchi TL8...
FORKS (A63276)
FORKS (A63276)
Arrow Quip 10' Corral Panel X 5 (A64047)
Arrow Quip 10'...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
2001 International 4000 DT 466E (A60462)
2001 International...
2015CATERPILLAR 329FL EXCAVATOR (A62129)
2015CATERPILLAR...
