Kioti KB2465 Backhoe Stablizers leak down sag problem
   / Kioti KB2465 Backhoe Stablizers leak down sag problem #1
appleo
Upstate, NY
Kioti CK30
Hello....I currently have a KB2465 Backhoe mounted on a Kioti CK30 gear, purchased second hand with 250 hours. Backhoe has seen little use. Prior owner used FEL mostly
Backhoe seems to work strong with the nuisance the hydraulic stabilizer arms appear to sag while operating the boom ... requiring frequent arms extension adjustment with the toggle lever
1. Fluids are full
2, Both cylinders affected sag
3. Two backhoe feed hoses color coded
4. FEL works strong and holds
5. Bypass valve under drivers fender opened the entire way
6. Fluid clear
7. Boom and scoop appear strong
Any ideas>?
Is there a hydraulic schematic available for the KB2465 Backhoe?
All and any ideas appreciated
Thanks! APPLEO
ALTEC CP12LF HYD (A52707)
ALTEC CP12LF HYD...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
2017 CATERPILLAR 262D SKID STEER (A52707)
2017 CATERPILLAR...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
2014 Ford Expedition SUV (A55853)
2014 Ford...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
