Old rusty Ford 545c industrial tractor 4x4 what do I need to know?
   / Old rusty Ford 545c industrial tractor 4x4 what do I need to know?
it really isnt too bad from the pics i too have seen much worse in this price range!
   / Old rusty Ford 545c industrial tractor 4x4 what do I need to know? #12
The 545 is the industrial version of the 4000 series AG tractor. The torque converter is needed for the loader versus slipping the clutch. The gear box is the same as the 4000/4600/4610.
anyone know how this would handle a large 3 point backhoe? Tractor data shows the 3 pt hitch on this thing is only CAT 1 rated which seems crazy for such a big heavy machine
   / Old rusty Ford 545c industrial tractor 4x4 what do I need to know? #14
The backhoes I have seen for industrial tractors do not mount on the 3 point arms. Typically, the arms are removed and the backhoe mounts on the pivot points for the 3 point arms. In some cases, there is a subframe that mounts under the tractor.
As to size, it is relative. Just saying that it is a large backhoe, you need to look at the weight and the force generated by the hydraulics. The recommended backhoe for this tractor is the Ford 764. You need to look at the 764 specifications and compare it to what you are looking at. 545 backhoe.PNG
   / Old rusty Ford 545c industrial tractor 4x4 what do I need to know? #15
I had a 3550 which is an earlier version of these industrial tractors. I believe it was a CAT 2, but the balls were replaceable so you could use CAT 1 or 2 pins. It says it can lift 3K Lbs so plenty.
I had a Prairie Dog 7.5 3 point mount on it. worked with no issues. I'm sure you can go 9 or 10' if you wanted. It's heavy tractor so I doubt you will break it. If you could find the actual backhoe that fits directly would always be better.
As to size, it is relative. Just saying that it is a large backhoe, you need to look at the weight and the force generated by the hydraulics. The recommended backhoe for this tractor is the Ford 764. You need to look at the 764 specifications and compare it to what you are looking at. View attachment 624861
Ya i know about the 764 but seems pretty hard to find a 764 around here with proper hydraulic installation kit and all. which is why i was looking for a simple 3 point hitch mount variety. the 764 specs are utilizing different anchor points i think not using the 3 point hitch. https://www.tractorbynet.com/forums/hydraulics/217017-ford-new-holland-345c-764-a-2.html i did some reading on this thread here.
there is a woods 1050 for sale locally for like 2k
   / Old rusty Ford 545c industrial tractor 4x4 what do I need to know? #17
p0opstlnksal0t; there is a woods 1050 for sale locally for like 2k[/QUOTE said:
You can always make a frame mount for it. And or keep looking for the 764. The 764 is probably not the only one that will fit, so you probably need to do some research on models before and after to see what will fit. And just keep looking.
i think theres a new holland variant identical to the ford 764
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2013 JCB 3XX Backhoe (A55973)
2013 JCB 3XX...
2016 Ford Fusion SE Sedan (A55853)
2016 Ford Fusion...
294 (A52706)
294 (A52706)
