   / Share Pics of People Hauling or Towing Something Wrong #11,091
It's the question I have asked many times. Do you need to secure something that secures your load in normal driving, or flipping end over end numerous times? Because, there is a difference.
   / Share Pics of People Hauling or Towing Something Wrong #11,092
I figure if I can drive it carefully and perform a hard stop it’s good enough.
   / Share Pics of People Hauling or Towing Something Wrong #11,093
Here is the applicable Kansas Statute:
No matter what happens, your load should stay secured. Exception for livestock as the container is enough.
   / Share Pics of People Hauling or Towing Something Wrong #11,094
So when that train hits you, “sorry, you didn’t secure your load”.
   / Share Pics of People Hauling or Towing Something Wrong #11,095
I haul pallets of manufactured fire logs. I put them right at the tailgate. They weigh a ton. They split into 3 pallets when the wrap and straps are removed. My tractor cam move them one at a time so they need to be in the rear. My truck is a 2500HD so it's fine back there. I have a piece of heavy OSB cut the same height and a little wider than the pallet. I stand it in front. It has 2 slots on each side to hold the straps in place. One at the bottom and one at the top. The straps go down around the pallet to the heavy duty tie point at the bottom rear of the bed. It can't go back due to the gate. The straps keep it from going forward. That is important as if I get in a wreck I don't want it coming to me. Where I buy them is 50 miles away but they have the best price. I am in the area every few weeks anyway for a meet I go to. If I roll over bets are off. Otherwise it will be good. As I have a CDL they won't cut me any slack on an unsecured load. So I have proper stuff to secure things in my truck or on my flat bed or tilt deck. Proper straps chains and binders if needed and the special connector hook sets the wrecker drivers use to secure my straps to car frames. Do it right and there will be no regrets later. The OSB also is handy between the fork frame and the 1/3 pallet. As the wrap is off it keeps the logs from sliding off the pallet when I tilt back.
   / Share Pics of People Hauling or Towing Something Wrong #11,096
From that perspective I could never haul sand, gravel, etc. No matter how well I tarp it, if I flip my truck the sand is going everywhere.
   / Share Pics of People Hauling or Towing Something Wrong #11,097
True. That’s where common sense has to play a part.
   / Share Pics of People Hauling or Towing Something Wrong #11,098
A law based on common sense?
Whoa!
   / Share Pics of People Hauling or Towing Something Wrong #11,099
A FL state trooper once told me "Common sense has no place in a conversation with a police officer."
   / Share Pics of People Hauling or Towing Something Wrong #11,100
I saw this yesterday evening. Newer Dodge 3500 dually with 14k gooseneck trailer with a Deere 5065E and B-series Kubota. Both tractors were 4wd with box blades so weight was fine. It is hard to see in the pictures but the only tie-down was a chain going across the lower 3-point hitch arms of the Deere. :eek: And it was just hooked on - no chain binder or anything.
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
CAT 312C EXCAVATOR (A58216)
CAT 312C EXCAVATOR...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2013 JLG 8K TELEHANDLER (A58216)
2013 JLG 8K...
