Loader Pallet forks
   / Pallet forks #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I have a 2006 Kioti CK30HST with a KL30 loader. Looking to install a pallet forks set up with bucket removed. I do not have a quick disconnect
   / Pallet forks #2
Add a quick connect...10-20 minutes knocking pins out and getting them to line back up is for the birds switching between bucket/forks.
When I bought my New Holland 1925 in 1998, dealer told me quick attach wasn't available for it. Found ATI company in (get this) NEW HOLLAND Pa that makes them for any tractor....just tell them the brand/model, and they have one.
Loader Attachments, Buckets, Grapples, Tach-All Quick Attach
Tach-All Quick Attach, Loader Attachments, ATI Corporation
QA-KM2 near the bottom of the page fits a KL 130 Kioti loader. Call for price.
   / Pallet forks #3
second that if you are going to add other equipment.
you would also need to convert the bucket to quick hitch.
are you going to lift really heavy objects?
if not clamp on forks work really great as well.... easy peasy on and off and much cheaper than all the above
   / Pallet forks #4
How to add pallet forks:
Step 1. Convert to quick connect. You won't regret it.
Step 2. Get quick connect compatible forks.
Step 3. Forever enjoy the benefit of having forks (very, very useful!) and other implements without spending 20+ minutes changing implements over.
:thumbsup:
   / Pallet forks #5
When I priced new forks, I found that the quick connect forks were less expensive than pin on ones.
   / Pallet forks #6
I have a 2004 model year CK30hst with the KL130 loader which is pin on. In 2007 or 2008, the CK30 and KL130 loader was made with a quick attach. I bought the Kioti quick attach adapter that fit perfectly on my loader arms using the bucket pins. I did see some aftermarket adapters but they were built heavy as to be on a 45 or more hp machine. Then I found an after market QA bucket and forks. It sure makes life easier than knocking out four pins every time you want to change. Just an idea but more cost than pulling the pins to switch.
   / Pallet forks #7
That make sense since one model fits all SSQA tractors, vs numerous pin on models for various tractors,,, lots of inventrory or build upon order. Just more hassle for the distributor.
   / Pallet forks #9
Once you've converted to SSQA, you can spend all of your money on those nice less expensive SSQ attachments. :)
SCAN TO RECEIVE TEXT UPDATES (A52707)
SCAN TO RECEIVE...
TRUCK PARTS (UPSTAIRS) (A55745)
TRUCK PARTS...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
2014 Ford Escape AWD SUV (A55853)
2014 Ford Escape...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A57024)
NEW 2025 Load...
