Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #11
Yeah, sliding doors have their own set of problems. I've seen that with a few neighbors. Tracks get full of junk and makes a it a real pain to slide a heavy door. If they get full of ice, then what?
I made swing doors on my junky shed, but as I rebuild it, I'm not sure what I'm going to do.
That is the issues I have seen with sliders also, I think I may just to the standard swing doors.
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #13
Hanging the track inside where it would be out of the weather might help.
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #14
I put in 10 foot tall insulated garage roll up doors on my shop, installed electric door openers. All is good, they are practically air tight and the foam insulation helps with the heat /cold so my shop stays warm in winter with very little heat input and it blocks the heat from the sun entering in the summer. I can work in it most of the time with just a shop fan and stay pretty cool.
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #16
You could go ahead and make a 8' slider and just make a "wing-wall" pocket for the door to slide into...from one side it would just make the building look bigger than it is...the wing wall could offer some protection from the elements for whatever might be stored behind it...
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #17
Or be one end of a lean to.
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #18
I've seen lots of sliding doors with tracks that extend beyond the building. A simple knee brace is all that's needed. That said, I've had enough experience with sliders that I wouldn't have one. For a few dollars more, an overhead door is much better.
   / Help needed between a 8 Ft Sliding barn door or two 4 Ft double doors Will slide #19
I agree. When we had our barn put up, the contractor said that the price difference between sliders and a garage door was negligible and he recommended a garage door.
Thanks for the help, I think I may stay simple and do 2 swing open doors, This is not an everyday building, Simple atv/dirtbike storage.
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
