Recycled Asphalt Millings for Driveway
   / Recycled Asphalt Millings for Driveway #21
Stuff works great here. It was easy to work and the hardened up nicely. I started putting cooking oil on the part that didn't harden and it fixed it.
   / Recycled Asphalt Millings for Driveway #22
Our town got a bunch after the state resurfaced some of the local road and they decided to see how it would work so they paved a dead end road near me this spring.
I am curious how it will stand up to the freeze thaw cycles we have here and more particularly mud season.
My main concern with it would be whether any petro chemicals will leach out and drain into the nearby waterways above my homestead.
   / Recycled Asphalt Millings for Driveway #23
Don't worry about it, anything that was going to leach out would have done it in the years since they originally laid the road.
By the time it gets ground up and re-used they get dried up. That's why some places grind them up, heat them up, add more oil and lay them back down.
Aaron Z
   / Recycled Asphalt Millings for Driveway #24
I get the impression that them re-using their ashphalt makes for a second rate finished road, and I think has fallen out of favour, hence them often giving the stuff away. I could be wrong. You would think,grinding it off, heating it up, adding tar on site and repaving, WOULD make sense, but I don't think it worked out. Maybe further grinding the ashphalt, is more expensive than just making new ashphalt with tar and crushed stone.
   / Recycled Asphalt Millings for Driveway #25
My driveway is about 4000 ft long. Half of it closest to the house is asphalt, the front half is gravel. Recently a highway resurfacing that started only a mile from the house made asphalt millings available. The asphalt company will sell millings but only if you are close to the project. If more trucking is involved they take back to the plant and recycle it.
It's been down on my gravel drive for 3 months. I like it better than gravel at this point. It is staying put better. BUT it seems street tires on my car sort of packs it down, but my utv with aggressive thread loosens it up, as well as my tractor with R4s. Recently sold my pickup otherwise I'd run it back and forth. It has been fairly hot here, in the 90s and very very dry, near drought status. Think lack of water is in part keeping it loose.
Thought of renting a roller from a rental place, but given what I'm seeing, wondering if it would be better buying a roller so it could be rolled once or twice a year. One that would weight 1200lbs or so and with water added around 2500 lbs. I could time the rolling better too, doing after a rain, etc. Reading through this thread seems there a definitely mixed opinions on the worth of millings. So far I find it considerably better than the gravel, but would like it to settle down better.
   / Recycled Asphalt Millings for Driveway #27
I'd imagine a hot dry day would be better than a wet one if there was any tar left in the mix. But there rarely is as the material is rarely in good shape when being removed.
   / Recycled Asphalt Millings for Driveway #28
Exactly.
Parking lots and boro streets, Etc. don't generally mill unless the pavement is dead and junk. So the millings often don't repack as well.
State roads are generally milled sooner and may pack better later.
But where the millings came from can have a big impact on how well they pack.
   / Recycled Asphalt Millings for Driveway #29
I see some of it sticking, but most isn't.
Some rollers have a water tank.... They apply water as you roll. And someone earlier in the thread mentioned rolling with water. So my understanding is water can help. Am I wrong?
   / Recycled Asphalt Millings for Driveway #30
IIRC, water helps keep the asphalt from sticking to the drum.
Aaron Z
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
iDrive TDS-2010H...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
