JD316 Onan Engine Seized
/ JD316 Onan Engine Seized #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I have a ~25 year-old JD316 Garden tractor with the Onan 2-cyl engine and about 700 hours on it.. I tried to start it recently, and it cranked for a bit and then stopped. After trying various things, I tried to turn the flywheel by hand and it is stuck. It won't turn either direction. Yes, I hit it with a block of wood and a hammer and still no-go. Yes, it has oil in the crankcase.
It ran fine a month or so ago. Does anyone have any ideas that are easier than pulling the engine and removing the oil pan? I fear that it has a broken rod, but even with that I would expect a little motion in the flywheel.
-Ortis
/ JD316 Onan Engine Seized #2
Here's what I would do. Repower Old Equipment at Small Engine Warehouse Go to this website and figure out what you need.
Your old Onan isn't worth fixing. Last time I looked about 20 years ago pistons were $600 each. Now you can't even find parts as Onan is no longer in business.
Edited to add: Make sure there is nothing simple wrong first before you spend big $. The electric clutch or a bearing could be seized for example.
/ JD316 Onan Engine Seized #3
Did you pull the spark plugs yet? Is it hydrolocked with fuel from a carb leak?
Thanks! I agree that it's not worth spending much money on. I did pull the plugs, buy the cylinders are dry. On the mag clutch, I was able to rotate the pulley by hand to help get the belt off. I am now working to disconnect the driveshaft just on the off-chance that the hydrostatic transmission is seized. However, without being able to rotate the shaft, the bolts are hard to get to.
The other unlikely possibility that I will check is that the starter pinion could be jammed against the flywheel, but that should have cleared when I hit the flywheel with a hammer. This machine has had repeated starter alignment problems.
My curiosity is piqued now, I want to figure it out if I don't have to waste too much time doing it.
Question: I've never had a bearing seize with screaming first. Do engine bearings ever do that?
-Ortis
/ JD316 Onan Engine Seized #5
most likely, the starter gear could be jammed against the flywheel. especially with repeated starter alignment problems. try removing the starter.. I had this happen to a briggs recently, the starter gear wanted to keep riding up past where it's supposed to..
/ JD316 Onan Engine Seized #6
My first onan had a cracked aluminum starter mount that I welded and beefed up. I never had another problem. My 2nd newer onan has been fine so far.
/ JD316 Onan Engine Seized #7
I agree with others pull the starter and see if it will spin.
I had an old jeep that seized on me over storage one winter. Ended up putting about 1/2 a cup of ATF fluid down each cylinder and let it sit for a day then got it to spin again by working the main pulley. Haven't had a problem since.
After trying a few other things, I hit the flywheel a couple more times, and it rotated. However, the starter still does not engage, even with a know good battery. My conclusion: the starter pinion was jammed with the ring gear on the flywheel. Either there is high resistance in the starter circuit keeping it from engaging properly or else the starter pinion is bad. Both of those have happened before. I'll either pull the engine to get to the starter when I get ambitious enough, or else I will get rid of it. I've been dealing with issues like this for 25 years.
Thanks for the advice. It helps to know that others have similar problems. I did look at the price of a new replacement engine, and the engine costs as much as the tractor is worth.
/ JD316 Onan Engine Seized #9
that's a JD316 Garden tractor, it would cost a bundle, many thousands of $ to replace it with something equivalent new, unless you can find a used garden tractor in good shape for a good price..
/ JD316 Onan Engine Seized #10
I say, perhaps you just need to replace the starter pinion gear and associated parts. You didn't say if the starter spins when you hit the start switch. If the starter does not spin, could be something simple as needing new brushes.
Richard
/ JD316 Onan Engine Seized #11
Not sure on this engine but a lot of these motors have magnets under the flywheel to make juice for charging the battery. Not too unusual for one of these to fall off, maybe get jammed up. But I'd really look at that starter drive first. Be pretty unusual for the engine to just lock up when not running.
/ JD316 Onan Engine Seized #12
Ortis, is this a B or P type engine?
P type solenoid mounted on the starter.
B type solenoid under battery tray.
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A62130)
(INOP) 2017 FORD...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2001 John Deere 1780 Planter (A63109)
2001 John Deere...
Ingersoll Rand Air Compressor (A61166)
Ingersoll Rand Air...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
