m5040
- Joined
- Nov 23, 2008
- Messages
- 1,013
- Location
- CT
- Tractor
- Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
For the record, I went with the grapple bucket. It is working out great and seems well made. I weighed it and found it to be 370 lbs. The shipping weight on the utility grapple was 380 lbs, so basically the same. Terry at Power Trac stressed that the utility grapple will bend if you try to crush with it and by looking at it's flat design I can see it bending if abused. The 1430 model grapple bucket seems more forgiving being it has a hyd cyl on each side and four bushings across the top shaft to keep it in alignment. Terry did say not to crush things with it also. Time will tell.
