Canopy Accessing blower motor on John Deere 4720 w cab
   / Accessing blower motor on John Deere 4720 w cab #1
wango tango
Peoria IL
mice have made a nest in the upper roof assembly on my JD 4720. I looked where the air filter is and could not find anything. But it smells bad, blows “bedding” out, and water was backing up in the roof area. I noticed because I’d been running it for a while and when I went over a sideways bump a bunch of cold water spilled out on me. :/
Anyone know the procedure to get to the blower motor? Presumably where the water was condensing and backing up.
   / Accessing blower motor on John Deere 4720 w cab #3
   / Accessing blower motor on John Deere 4720 w cab #4
Dern 'ole mice....they get in anywhere. I'm allergic to mice homes and what the critters leave behind so I'm always at war with them.:punch:
The cloth Fresh Cab rodent repellent works for me. You can zip-tie the packets where the mice want to congregate so they stay away. Also, the sorta pleasant odor the packet gives off over-powers the mouse smell some. Since I have been trapping mice year round, I have noticed less mice, mice damage, and less ticks. If you scrub the nasty mice areas with pine-sol, it keeps them away for a while too. grrrr :punch:
That did it!!! Thanks everyone. I pulled the roof off and cleaned it out good. Much better.
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
1993 CATERPILLAR 416B BACKHOE (A52707)
1993 CATERPILLAR...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
