Cutting corrugated roofing
/ Cutting corrugated roofing #1
sodamo
Super Star Member
Big Island, HI
Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Have the opportunity to get some 29 gauge galvalume roofing panels for my carport project.
Challenge is the panels are 12ft and I’m planning on 26 ft , meaning I would need to cut 4 panels 3 times resulting in 16 3ft sections.
What would be best way to make such cuts resulting in nice clean edges that would be exposed? Can I cut all 4 panels together or just individually?
I could just buy 26ft panels, but plus $2/ft more make the galvalume deal attractive.
/ Cutting corrugated roofing #2
I've got that same roof. We cut it using a metal nibbler. I cut them one at a time because our cut end was going to be hidden.
I loved the galvalume so much I have it as my ceiling in my shop too.
/ Cutting corrugated roofing #3
I had to cut all my aluminum roofing with a thin carbide blade on my Skill saw. The cut were fine. I cut four panels at a time.
/ Cutting corrugated roofing #4
I use a thin cut off wheel on a hand grinder. Cut all four at once if you want. Just clamp them so that they do not move while cutting them.
/ Cutting corrugated roofing #5
If you have access to or could rent or borrow a plasma cutter that might work for you. The sheet metal nibbler would probably be a less expensive alternative but I don't think the edges would be quite as nice.
/ Cutting corrugated roofing #6
Probably a metal abrasive blade in a skill saw would give the cleanest cut 1 at a time or clamp them and cut slow so you don't burn the saw motor out.
/ Cutting corrugated roofing #7
I cut it with a woodblade turned backwards in a circular say. Wear hearing protection and eye protection. Clamp it down
/ Cutting corrugated roofing #8
I used the metal abrasive blade in my skilsaw as mentioned above, with the roofing upside down on two by fours to keep from crushing or scratching it.
Thanks guys.
Leaning toward circular saw. I have a nice Rigid worm drive. Just need to decide which blade. Would prefer cutting all 4 at once. Going slow not a problem. Hoping for edge that requires least dressing before painting. One edge would be exposed but might cover with an 90° edge trim. The other edge would most likely be visible inside carport, unless it lands on purlin.
/ Cutting corrugated roofing #10
I turned the four sheets over and cut them all at once from the bottom side. If there were going to be any "raggie stuff" I wanted it to be on the bottom. It turned out good. If you do end up using some kind of blade in your worm drive - use eye protection and a FULL face shield. And a work jacket. I picked tiny, tiny chunks of AL out of my hide for a day or so. A little festered red spot would show up - pick at it with a sharp pointed knife. Dig out a tiny chunk of AL.
Big mistake on my part - I only wore a short sleeve T-shirt. I DID wear safety glasses and a full face shield.
/ Cutting corrugated roofing #11
I have heard but are unable to confirm abrasive wheel is not recommended the small sparks that come off wield to the surface and are not able to be brushed off which then promotes corrosion nibbler is the way to go If it was me I'd go for the more expensive single length option less hassle quicker put up and will last longer the lap joints are always the first place to fail
/ Cutting corrugated roofing #12
Also earplugs are a good idea. I never thought of doing them all at once, I always do manage to find the hardest way to accomplish anything.
/ Cutting corrugated roofing #13
Bingo. Metal roofing manufacturer told me the same, directly from the horses mouth. Only use shears to cut, no saw blades or abrasives as the chips/dust will cause rust to start quickly as they imbed in the surface of the panels. They said that would void warranty, which isn't an issue here as it sounds like these are not new, but still seems like sound advice. ...Unless you just don't care, in which case a circular saw would easily be the fastest and straightest way to go....
Good points, Rolf.
When we built the house we used structural metal roofing panels, finished metal panel each side, R20 foam in between. Had to cut 2 panels each roof (5) on both sides due to thickness. These were for width, splitting each panel into useable sections, 1/3 & 2/3 width as I recall. Longest panels were 30ft. Basically freehand, following chalkline as I had no way to fix a guide. Interior, flat side was easier than ribbed exterior. But, boy, what a mess. Noisy as **** using the worm saw with a metal blade and wax lube.
/ Cutting corrugated roofing #15
Circular saw with the blade reversed cuts it well.. It makes a racket that's for sure..
/ Cutting corrugated roofing #16
Skill saw with fine tooth carbide tipped blade, and cut from back side....and GOGGLES UNDER FACE SHIELD and cover up really well..... Sounds extreme but the saw will spread the shards everywhere, its like beach sand gets in every crack or crevice.....Its no fun going to ophthalmologist to get metal shard removed for eyeball....
If you need saw guide lightly clamp a length of 2x4 on each side of panels and use bolts or threaded rods to secure....
Dale
/ Cutting corrugated roofing #17
I was able to get 7 1/4" metal cutting circular saw blades at Home Depot a couple of months ago. I cut 4 sheets of galvalume U- panel at a time. Really clean cut. I think they were 28 or 30 carbide teeth. They are used in the normal rotation, the teeth are almost "flat" at almost 90 degrees to the blade. They weren't expensive at all, around $10 or $11 each. I bought 2 of them thinking they would wear out quickly, but lasted for cutting the whole roof (about 30 panels). It's still very noisy and a lot of chips.
I would do a search for "metal cutting blades at Home Depot " ... That's how I found them. They were in stock at my local store.
/ Cutting corrugated roofing #18
I had some white used roofing that I placed on coop. I cut it with a Lennox metal max blade. This us a diamond abrasive blade that cuts with a lot less sparks than a cutoff wheel. I have had no rust spots and until lately it has been wet.
/ Cutting corrugated roofing #19
Electric sheet metal shear works well, a bit slower than a circular saw but much less mess. Just long curls about a quarter inch wide, gloves are a must, they are sharp. Got mine from Grizzly, $80 for electric (don't recall paying anywhere near that), they also have pneumatic for $45.
I have the pneumatic shears, like them for cuts with the corrugation, not so much across it, especially that many cuts.
Kuhn FC400RG (A60462)
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Mini drum mulcher (A61567)
Mini drum mulcher...
SDlanch 12'x20' High End Carport (A60463)
SDlanch 12'x20'...
2016 KOMATSU D65PX-18 BULL DOZER (A60736)
2016 KOMATSU...
