   / Share Pics of People Hauling or Towing Something Wrong #10,891
I don’t understand how this is legal, but
The State of Maine offers cost-effective long-term trailer registrations that are consistently priced lower than most other states, and we are able to offer them to customers across the US. For many of our customers, the tax and registration savings that Maine can offer really makes a huge difference every year.
Home - Maine Trailer Registrations
   / Share Pics of People Hauling or Towing Something Wrong #10,892
Am I towing my Jip the right way?
Iron Bull 14K hauler.
Chains on rear axle.
3,300 lb straps to front axle that is wrapped with sleeved axle straps.
Ram 1500 with 1050 payload/10,640 towing.
Reese 10k WDH (no sway control).
   / Share Pics of People Hauling or Towing Something Wrong #10,893
If you want to be picky the tie down angles are supposed to be 45 degrees and you’d be better off moving the front hook points back.
   / Share Pics of People Hauling or Towing Something Wrong #10,894
The straps are likely around 20 to 25 spread out.
I do plan to weld in at least 3-4 more pairs of D-Rings. This trailer is new a couple months back and I just haven't had time to add the rings. On my utility trailer I bought in early spring I added 19 D-Rings... I love having them all over the perimeter.
   / Share Pics of People Hauling or Towing Something Wrong #10,895
Depending on the load in the trailer you might be ok with 3 wheels.
They would be okay by what standards? They ought not be on the road by my standard. Yikes!
   / Share Pics of People Hauling or Towing Something Wrong #10,896
What’s the problem if he’s not overloading the one axel?
   / Share Pics of People Hauling or Towing Something Wrong #10,897
It is not going to brake and handle correctly for starters. Even if the brakes are only on the rear.
   / Share Pics of People Hauling or Towing Something Wrong #10,898
Actually it'll handle/brake fine as long as its not overloaded and the weight is distributed correctly. I've had to move a tandem axle trailer like that before due to a bent axle (had to run on the front axle only which was not as easy as the rear).
I've also had to turn my triple axle into a spread axle tandem on the side of the highway so I could get it to somewhere to replace a tire, it was loaded to max for only 2 axles. Luckily it was a gooseneck and I could load the tongue pretty good since I was hauling 2 crew cab longbed 4x4 diesels, 1 was a dually.
And I'm guessing it has both front wheels off and is only riding on the rear axle based in how its sitting.
   / Share Pics of People Hauling or Towing Something Wrong #10,899
If it’s not overloaded is the key words. Otherwise it’s going to brake and handle fine.
   / Share Pics of People Hauling or Towing Something Wrong #10,900
What if the brakes are on the front axle? We do not know nor do we know from that fuzzy picture that it is loaded correctly. I have a hard time thinking that is legal.
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Bucket (A55973)
Bucket (A55973)
