Side by side tire tread direction
/ Side by side tire tread direction #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Dealer Pic below looks like the front tread direction is consistent with tractor tires (pushing the dirt away from the tire somewhat) but the rear direction looks opposite from the front. Is one of these pairs on backwards?
Thanks.
/ Side by side tire tread direction #2
I'd say the rears are, swap sides and roll on.
Thanks. Before I ask them to correct it before I buy it, I just wanted to confirm it's backwards.
/ Side by side tire tread direction #4
yep - needs switched side to side in the rear as Shaneard mentioned.
Someone mounted them on the machine too quickly and didn't pay attention im guessing.
/ Side by side tire tread direction #5
Before asking for them to be swapped look for a rotation arrow.
Most tires with a directional track will have an arrow showing rotation direction.
OP here.
You were right about the arrow and the tires were properly mounted after all.
Just brought it home and hope to be riding it tonight.
Thanks.
/ Side by side tire tread direction #7
OP here.
Thanks.
Interesting. I'm guessing the fronts have the chevrons pointing toward the front of the vehicle to channel water outward, aiding steering. And that the rears have them inverted for traction. :scratchchin:
Since the tires are directional, I'm then wondering how you should rotate them, if ever you did. Would you swap them front to back, so they continued to rotate in the same direction? Or swap them diagonally so that the tread orientation remains the same? :confused3:
/ Side by side tire tread direction #8
OP here.
Thanks.
Are you sure you read the arrow direction right. The rears sure seem to be on backward and if used in the mud they are going to load up rather than shed the mud. Any tire with chevron pattern is always ran with the chevrons pointed up and to the front when viewed from the back.
I dont suppose it will make much difference as long as you dont get into a thick mud.
As to one post mentioning rotation, you dont. Fronts are different size so cant swap front to rear. UTV owners dont generally have to worry about uneven wear that would need rotation. The tread should wear down evenly and need replaced in about 600-800 hours if you keep off the asphalt with them.
/ Side by side tire tread direction #9
Gary, except that jmc's side-by-side is the new Wolverine X2, so I looked at some pics and videos on the Yamaha website. They, too, all seem to show the rears with the chevrons inverted, as in jmc's pic.
You are right about the fronts and rears being different sizes, at least stock: Fronts: 26x8-12, rears: 26x10-12.
Top speed is reported to be 50 mph, stock. :eek: Aftermarket accessories are available that claim to make it street-legal. IMO, life is already too short to drive one of those that fast on anything other than a speed track. :laughing:
OP again.
Up close, those rear chevrons aren't that aggressive laterally, and some of the tread near the tire edges are oriented in the opposite direction. Might be a compromise tread pattern for traction in reverse too.
Dealer warned to take it easy at first to break in the CVT belt. I did run it up my driveway (pic below) at 30 MPH. Although it seemed like about 60 MPH with the grade, dips, curves and no windshield, the ascent was effortless and stable.
/ Side by side tire tread direction #11
My defender HD8 is pretty stable at 45 mph (on DOT radials - street tires make a huge difference!). It will supposedly do about 60 mph. Some of the 1,000 class models will do 70 mph +. They would just have to do it without me in it.... With certain equipment installed we can tag them for the road here. It is limited to secondary roads. Most anywhere I would drive it is 45 mph or less, so the HD8 is plenty adequate to keep from holding up traffic (what little we have...). The SxS is great for exploring some of the mountain roads we have around here. You rarely hit even 30 mph on most of them. It makes for a nice evening ride.
/ Side by side tire tread direction #12
Some guy around me uses his ATV as transport (I suppose) since he daily zooms by my house at 50+ MPH. I wouldn't want to have to buy tires for him what with all the road travel. Off road tires dont last long with lots of pavement use.
/ Side by side tire tread direction #13
That's why I changed mine out. The Bighorns that came on it wear fast enough in dirt. A little bit of pavement work would eat them alive. I'll save the originals for the OHV park.
/ Side by side tire tread direction #14
No doubt about ours being on the correct way: :D
/ Side by side tire tread direction #15
A lot of newer side by sides handle extremely well....I used to feel that those speeds were insane....now after driving my Polaris General at 70 it handles like champ....they have come a long way
2017 TRAILEZE TE80 HTS LOWBOY (A65057)
2017 TRAILEZE TE80...
2003 Ford Mustang Coupe (A66738)
2003 Ford Mustang...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
