Briggs sheared key
/ Briggs sheared key #1
Alan W.
Kentucky
Kubota L3650 & Bobcat 763G & Craftsman DGS6500
Hit a small piece of wood hid in the grass with the push mower and it died. Tried restarting but no go. Sounded like it was trying to kick back. Pulled the flywheel and yep the key had sheared. Didnt have the right size key stock so my son milled one down to size. Briggs forgot to tap the holes for the puller on the flywheel. Back to one pull starting.
/ Briggs sheared key #2
Was the key made of steel or aluminum?
/ Briggs sheared key #4
Last time I removed a flywheel with a puller, the puller had two self tapping screws that went into the holes in the flywheel. I don't believe they were threaded.
I'll leave it to Ruff to explain why the sheared key was aluminum.
/ Briggs sheared key #5
They don't make things like the use to.
/ Briggs sheared key #6
Yes, the aluminum key. When the blade hits something solid and the crankshaft momentarily stops, the flywheel wants to continue spinning. If it had a steel key, it would not shear so all the twisting force goes into the crankshaft. It is easier and cheaper to replace a sheared key than a broken crankshaft.
/ Briggs sheared key #7
Or explain why there are parts of a flywheel embedded into somebodies body parts when it fragments.
It did crack the flywheel a bit in the keyway. Or the crack couldve been there. Who knows.
Its got a scatter shield on it. 😁
Its weird they put an aluminum key on a light flywheel that lacks a lot of inertia but on the bigger motors with the heavy cast flywheels its steel for the key.
/ Briggs sheared key #10
With a steel key, the next wood strike will require a new flywheel.\ DTDT and I have the evidence.....
A wise man learns from the mistakes of others.
/ Briggs sheared key #11
Its got a scatter shield on it. ��
Most briggs engines use an aluminum flywheel key. The Vanguard is about the only exception and some of those are aluminum. And you will think scatter shield up until you see an aluminum flywheel shatter and tear the blower housing completely off of the engine.
/ Briggs sheared key #12
Do the larger engines with steel keys have a blade bolted to the opposite end of the crankshaft?
Good point Ill have my son pick up or make another one out of aluminum.
/ Briggs sheared key #14
Briggs aluminum flywheel keys are so common at one time you could pick them up at the grocery store. Now any dealer, walmart may have a multipack, as well as Menards, Home Depot, or Lowes.
/ Briggs sheared key #15
It was aluminum. The replacement is steel.
I worked in a mower shop during high school and college. You do NOT want a steel key in a small engine. It will do a lot of damage if it hits something.
Flywheel keys are cheap. They used to be about a quarter each, but now it looks like they're 3 for $4.99.
Make sure you get the nut on top of the flywheel torqued down tight! If you don't, the key may shear again even without hitting anything. There is a washer on the top of the flywheel. It should be conical so there's a "top" and a "bottom" to the washer. Be sure that you put it on correctly.
Apparently in a cost saving move Briggs quit putting the belleville washers on some engines and mine is one of them.
/ Briggs sheared key #17
Bigger engine = bigger flywheel = more inertia. The bigger engines will shear the steel key. Either go buy an AL key are start saving for a new mower the next time you hit something.
Also, depending on the engine application, they don't expect the engines to get the shock of hitting something like a directly mounted blade on a mower. Most drive systems will absorb some shock.
