Horsepower rating vs pulling power - 3039R vs 3046R
   / Horsepower rating vs pulling power - 3039R vs 3046R #31
I'm betting in low range, they'll both spin front and rear wheels on an MFWD machine.
The higher HP tractor will do it more easily.
   / Horsepower rating vs pulling power - 3039R vs 3046R #32
I agree that would be the probable outcome, but if you were not traction limited, I think both tractors would send the HST into relief.
   / Horsepower rating vs pulling power - 3039R vs 3046R #33
It’s a pointless argument. It’ll never happen that way UNLESS you’re in a higher gear trying to gain speed. Weight/traction beats HP every time.
   / Horsepower rating vs pulling power - 3039R vs 3046R #34
As long as you don't enter time in the equation.
For those making a living with their tractors time is ALWAYS in the equation. That's why tractors are built with varying HP.
Back to the original question. Yes, the higher HP tractor will do the task quicker and more effectively. It's not rocket science. :)
   / Horsepower rating vs pulling power - 3039R vs 3046R #35
Plus the extra hp comes in handy for PTO use...and they are chick magnets:thumbsup:
   / Horsepower rating vs pulling power - 3039R vs 3046R #36
Weight and traction are not part of the debate. The op is comparing 2 identical tractors except engine. Why complicate things?
Save your point when someone is asking about a 10,000 pound 50hp tractor vs a 5,000 pound 65 hp tractor. :duh:
   / Horsepower rating vs pulling power - 3039R vs 3046R #37
Have I or anyone else said more hp won’t pull faster or in general do more work? No. But more HP won’t pull harder with everything else being equal.
   / Horsepower rating vs pulling power - 3039R vs 3046R #38
Pushing snow requires weight and traction. So how can that not be a part of this?
If, the same weight tractor CAN get enough traction, the higher HP will move more snow faster. Once wheels slip, hp matters not.
   / Horsepower rating vs pulling power - 3039R vs 3046R #39
I don't think this will prove true in this scenario with an identical HST tractor with only marginal HP difference.
I don't think the extra HP will come into play until the engine is lugged and trying to keep the hydraulic pump at full input speed when the machine is under heavy tractive load and there is no wheel slippage.
I general run out of hydraulic driveline pressure long before I notice the RPMs drop in my machine. There was practically no difference with my virtually identical machine when I had my smaller-engined Massey 1648 compared to my 1652.
I traded up to the larger engine for more PTO HP, not tractive power.
   / Horsepower rating vs pulling power - 3039R vs 3046R #40
I said that because the tractors that the OP are comparing are the same weight and identical other than HP. So there is nothing to compare. To keep talking about weight and traction is just a distraction from his question.
Of course weight And traction are important
Willmar 4550 Wrangler Articulating Loader (A57024)
Willmar 4550...
Utility Cart (A55851)
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2020 MACK P164T (A58214)
2020 MACK P164T...
1974 John Deere 6030 Tractor (A55315)
1974 John Deere...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
