Kubota Z122R Mulch Kit Install
   / Kubota Z122R Mulch Kit Install #21
(this is my disclaimer :) ... I have a 121S, which has the 3-blade set up... so I may be speaking out of my rear in regards to the 122R you guys have, but trying to be helpful... it could be entirely different!) :) Yep, I love working on the thing.. but I didn't want to remove the deck, wasn't sure how on quick glance. I have a mower lift due to the black clay soil we have. I clean the underside frequently enough to need a lift.. comes in very handy. For the mulcher kit, make it easy on yourself and lay it out BEFORE you try to install it. You'll notice Kubota made them fit in a certain order... some of the parts 'stair-step' into each other. You'll also notice there are a few predrilled holes in the mower deck that will provide support bolt holes to hold onto the mulch kit.. Good luck!!!
Im guessing your 121 kit was a little more complicated (more pieces)... But great advice regardless.
   / Kubota Z122R Mulch Kit Install #22
i know this is an older thread, but does anyone have a part number for the z122R 42" deck mulch kit? also, bump this up for opinions and reviews of the mulch kit?
   / Kubota Z122R Mulch Kit Install #23
Reviving old thread. Removed and sharpened my blades and after reinstall, I am getting lots of vibration... actually threw the belt. Found that one of the pulleys nuts was very loose. Remounted the belt, retightened all the bolts and still am getting some vibration. Took the blades off... no vibration. Swapped the blades and less vibration but more than what I am comfortable with for operation.
The blades were pretty beat up and I did remove a fair amount of material with the grinder. I think next step is to purchase new blades. Now just need to find the replacement blades!
   / Kubota Z122R Mulch Kit Install #24
Problem mostly solved. Picked up new mulching blades from my local Kubota Dealer. Installed and vibration issues gone. One blade on spin down does hit the deck a bit. Not enough to try to fix. Figure it will wear soon enough and stop.
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
Informational Lot - Financing (A52128)
Informational Lot...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
