Delay fall bush hogging for pollinators?
/ Delay fall bush hogging for pollinators? #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Below is a comment about bush hogging later in the fall, for the pollinators' sake. It was sent to me without a citation but it seems reasonable:
"DO NOT MOW/BRUSH HOG DITCHES & FIELDS RIGHT NOW!!! I almost just crashed my car on my way home as I witnessed someone mowing down an ENTIRE field of blossomed goldenrod. PLEASE PLEASE PLEASE wait to do this "fall cleanup" until it has dried up! Many may not realize that in Wisconsin and surround Midwestern states, a field of goldenrod like pictured is the last major nectar source for honeybees and other pollinators to prep for winter. This literally can mean a matter of life or death for wild pollinators as well as human maintained colonies. Please do your part to "Save The Bees"!"
On a related note, I've live on the same property for 27 years and used to slow down when mowing thru clover in my yard because of all the honey bees. Lately there are hardly any, like 2, this year. Still seeing bumblebees, for now.
/ Delay fall bush hogging for pollinators? #2
My aunts fields have grown up and all the weeds are in bloom now. My son told me that the blooms are loaded with honeybees and other pollinators.
/ Delay fall bush hogging for pollinators? #3
I get what you're saying, and try to leave wildflowers un-mowed as long as possible, but sometime you've gotta do what you've gotta do when you have the time. I do avoid using pest/herbicides.
We had plenty of all sorts of bees earlier this summer, especially when the milkweed was in bloom. Now it's mostly just bumblebees.
/ Delay fall bush hogging for pollinators? #5
This was a strange year. For the first half of the summer, we didn't see ANY bees. I talked with others about this and they are all wondering where the bees are. I have patches of white clover and normally it is full of small bumble bees. Not this year....NONE. Later in the summer we did start seeing a few but we are still down 95%. Even the wasp/hornet population is nearly gone. We are seeing more butterflies though!
/ Delay fall bush hogging for pollinators? #6
Odd year in Wisconsin indeed. Like you, very few bumble bees and the wasps are only starting to appear now (not that I'm complaining there). We have a small wild flower patch (approx. 200 sq ft) that never really took hold because of a wet/cold spring and when it did the grasses had already taken over. That's my guess as to the reason for the lack of bees.
/ Delay fall bush hogging for pollinators? #7
The down side is that if you wait that long, you will end up with an ever increasing amount of weeds in your field. There is or was a federal program which paid people to not mow until late August, when nesting birds had raised their young and wouldn't get killed. OTOH I'm trying to knock back an invasive plant (Autumn Olive) in my mother's field, and make it a point to mow in July before the berries have time to mature. Birds will eat those and drop them miles away, spreading the plant farther.
/ Delay fall bush hogging for pollinators? #8
I have been mowing my fields late in the season for years. One field was being hayed by local farmers for years but it was rutted up pretty badly earlier this year so I will probably tell the farmer to stop and let it go to wild flowers. I have tons of different types of bumble and other bees including honey bees from my hives. I doubt I would have so many if I cut on a regular basis throughout the season.
There is a good reason you may not see many bees early in the season. Only honey bees overwinter as a nest in colder climates. All other bees, wasps, and hornets have individual newly mated queens overwinter in some protected spot. So, in the spring, they start new nests with one individual. As the summer progresses, the nest grows and so does the population. At the end of the season right before frost, they are at their peak populations. Then they die off and start the cycle all over again. It is a natural part of the cycle to see more pollinators late in the season than in the spring.
The statement about nectar being important at the end of the season is spot on. My honey bees are currently working the asters and golden rod building supplies for the long winter months here in Maine. They need about 100 pounds of honey for each hive to make it through the winter. That requires a lot of flowers. Other pollinators are raising the queens that must be healthy enough to survive the winter to start new colonies in the spring. And other pollinators, like the Monarch butterfly, need those flowers to supply food stops during their long journey from northern areas back to their overwintering grounds in Mexico.
As far as trying to get rid of invasive plants go, I might just ask one question. Is it possible to target the problem plants without cutting the entire field? Even leaving a portion of the field as a wild flower meadow can be helpful.
Personally, I think more folks should consider leaving at least a portion of their unfarmed fields as natural meadows instead of cutting them regularly as lawns. Not only will you help save the necessary pollinator population from decline, but you will save yourself hours of cutting and gallons of fuel and the resulting exhaust emissions. Those fields also provide nesting areas for birds, etc.
/ Delay fall bush hogging for pollinators? #9
I'm pretty sure Kansas never got this memo.
/ Delay fall bush hogging for pollinators? #10
That is part of my long term plan but right now I'm just trying to keep it from spreading, which means knocking it back before the berries mature. This year I spent two days cutting and stump treating the shrubs growing in the tree line, then hauling the brush off to a brush pile; my brother mowed the fields to knock what's growing there back. Next year I plan to cut and treat a few shrubs which I missed then spot spray the plants in the field, which will take several days. It's 200 miles one way, and every time I go down there I do about half of what I want to accomplished. I've IDed 6 different invasives on the property, 3 of which are causing problems. I just found out today that we also have bittersweet taking over the fruit trees, so that's now on my list for next year when I prune them.
My father always kept it mowed as a hay field, goldenrod and milk weed are banes to that goal. Besides, there are plenty o areas which don't get mowed; and since we no longer pick the apples, the fallen fruit is also a haven for bees and hornets.
/ Delay fall bush hogging for pollinators? #11
Exactly. There are consequences to all activities. A balance of cost/benefit is only determined by looking at the big picture.
/ Delay fall bush hogging for pollinators? #12
Instead of planting beans or corn, a friend of mine planted 80 acres of a mixture of wildflowers. Different flowers will bloom at different times of the year so the fields change colors.
/ Delay fall bush hogging for pollinators? #13
/ Delay fall bush hogging for pollinators? #14
I have 70 acres in USDA Pollinator program. Cutting cannot be done prior to 15 July or later than 01 Sep. Cutting is limited to invasive species control. A field can only be 100% cut by special permission.
/ Delay fall bush hogging for pollinators? #15
I'm confused. I'll admit I'm not familiar with growing seasons in Missouri, but those dates seem backwards. You'd think July 15-Sept 1 would be prime wildflower season and that cutting would be discouraged during that time.
/ Delay fall bush hogging for pollinators? #16
As someone mentioned, don't want to cut dyring nesting season. Don't want short growth going into winter.
/ Delay fall bush hogging for pollinators? #17
Nice reminder and confirming my actions of a non-educated novice. Rains are coming in finally and went out to cut the weeds. This acre and half had hug patch of tall skinny plants with tiny purple blooms. Loaded with orange and purple butterflies and bumble bees. So I only cut around where the coastal was growing. Want the coastal to overtake the front pasture. Left them a about 80 square yards of the plants since coastal has not taken hold there. Slowly watched them migrate over to the portion.
So do not feel to bad about destroying their habitat.
I did out of ignorance cut down a shrub loaded with Monarchs this spring. Luckily the shrub did not die.
Could not identify the plant but had a soft fragrance.
Soon as I learn what it is, may plant a few more to help increase the butterfly population.
A side note the hummingbirds are back! yeah....don't take much to excite me.:laughing:
OP here.
The like minded responses here are encouraging.
Someone once compared our environment to a game of Genga- a stack of blocks where the idea is to remove a block without the stack collapsing. Fun part of the game is that eventually, removing a block will collapse the whole structure, thanks to all those previously removed blocks that didn't collapse it immediately. Not fun in real life though.
USDA came out today on planting a pollinator friendly area up here. She knew every plant on my property and if it was native or not.
Waiting for her proposal on what is a two year process of mow, glyphosate, mow, glyphosate, plant, mow high when the unavoidable weeds form seed,... She also said the for first two years or so, most of the seeded native plants are developing their root system and you just need to be patient. She estimate a native wildflower seed mix at $1200/acre.
/ Delay fall bush hogging for pollinators? #19
It's very, very expensive.
Yeah, since that meeting, I was thinking of you with your 70 acres.
For my small plot, I'll probably just eat the seed/Roundup cost to avoid paperwork and just depend on USDA for guidance. I hope that $1200/acre isn't because our government is subsidizing most of the seed.
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
1994 WELD-IT COMPANY 130BBL FUEL PUP TRAILER (A67714)
1994 WELD-IT...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
