Caution Catastrophic FEL failure
/ Caution Catastrophic FEL failure #1
a4763218b
john deere 5525
Westendorf Loader FEL
New Westendorf loader has skid steer style bucket. Safety latches are inadequate and release bucket
/ Caution Catastrophic FEL failure #3
Re: Westendorf Loader FEL
There are many reports here on TBN of independent supplier buckets with sloppy
SSQA fits. If Westendorf didn't make your bucket too, the problem could be with whomever did.
/ Caution Catastrophic FEL failure #4
Same can be said to you Jeff.
/ Caution Catastrophic FEL failure #5
Somebody needs to explain to me how a bucket can come off the loader quick attach device and land in the operators lap.
I followed the link, read the report. The single attached photo does not support the narrative.
All new Westendorf equipment
Backdragging, caused safety latches to become dislodged. Never seen anything like it
/ Caution Catastrophic FEL failure #8
Backdragging is a good way to overstress the QA latches. I’ve seen it, I’ve seen loaders improved by manufacturers because of it. But how a bucket can end up in the operators lap is well beyond my comprehension.
/ Caution Catastrophic FEL failure #9
Maybe he needs to learn the proper use of the equipment.
/ Caution Catastrophic FEL failure #10
I'm thinking it rolled down the FEL arms?
/ Caution Catastrophic FEL failure #11
The OP has been bashed several times for multiple posts, from what he has said I think he was just trying to get sufficient post count to attach a file and unaware of forum etiquette so perhaps give him a break. A loader bucket can end up coming down the loader arms onto the operator if the pins securing the bottom part of the bucket fail and the bucket is curled back at near full-height lift, essentially the bucket is tipped out of the quick-hitch. A very scary proposition, a fractured femur is a serious injury but he was fortunate not to have been killed.
/ Caution Catastrophic FEL failure #13
One thing we've all learned with machines is that there are no absolutes. Odd things can happen when least expected. This is not the first thread that has mentioned failed Q things. There was another that mentioned the bucket frequently falling off when doing various things. So damage from one task and failure while doing another could be possible. Backdragging did the damage but raising to full height is when it fell off?
/ Caution Catastrophic FEL failure #14
I want to see these pictures from the tractor side:
And a closeup of the latching pins of the bucket when it is in the closed and latched position (as well as hear how it ended up breaking the femur of the operator sitting in the drivers seat):
Aaron Z
/ Caution Catastrophic FEL failure #15
I'm confused, how did the bucket fall onto the operator's leg? I'm trying to picture that and I don't understand how that happen if he was sitting in the seat.
Also, if you are having an issue with a bucket, I understand the first time not knowing and when it happens a second time, wouldn't you stop using it and not keep trying?
/ Caution Catastrophic FEL failure #16
I'm guessing he was back dragging the bucket and the latches released but he didn't realize it. Then when it was raised high and curled back, it came off and slid down the loader arms onto the operator's lap.
/ Caution Catastrophic FEL failure #17
There have been a couple threads on here where people had issues with the quick connect on the bucket not latching properly and the quick release for the loader arms popping off.
I think the loader arm one was with a John Deere and the owner missed that it was unlocked.
Aaron Z
/ Caution Catastrophic FEL failure #18
Ok, I guess another reason to have a good cab.
/ Caution Catastrophic FEL failure #20
I’ve had my forks come off my aldomi quick attach setup on my ford 1720. But darned if I didn’t forget to latch them down. First and last time for that.
2017 International Prostar 122 Day Cab (A62613)
2017 International...
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
2013 Dodge Durango AWD SUV (A61569)
2013 Dodge Durango...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
Zero Turn Mower (A59231)
Zero Turn Mower...
