Dataway
Gold Member
I've got a 1715, single clutch type, about 1000 hours. I've replaced the throwout bearing once a couple hundred hours ago.
Is my memory serving me correctly that the throwout bearing is in a "Dry" area of the transmission?
The original throwout bearing died due to lack of lubrication and the cavity it was in was covered in condensate produced rust ... it wasn't a sealed bearing and I figured it wasn't going to last long.
Anyway ... has anyone ever drilled a hole in the outer case (assuming it's dry like I remember) to be able to squirt some oil on the bearing periodically? I can't remember if the clutch itself is dry or wet .... obviously it would cause problem getting oil on a dry clutch. Hate to split the tractor again just to replace this bearing that would probably live quite a bit longer with some oil on it.
And ... a bonus question ... would you 1715 owners expect the clutch to slip going up a hill about 25 degree incline, with a bucket full of gravel, a full frame backhoe installed and filled tires .. using mid-range 2nd gear? I've gone up the same hill in the same gear without the gravel many times in the past no problem ... pretty sure it was slipping carrying the gravel ... changed to 1st gear, mid-range and it goes up with no sign of slippage.
