324 or 424?
/ 324 or 424? #1
USAF93
Lydia Virginia
Yanmar SA424
I'm sure this has been a topic but I couldn't find it in my search. What are the pros and cons of a 424 over the 324? Is it just ground clearance?
/ 324 or 424? #2
Yes. 424 has larger tires. So traction and weight should be better.
I have a 424 and so far, it’s done all i needled.
I like it.
/ 324 or 424? #3
Had to make this same decision a couple of years ago. Went with the 424 for the larger rear tires. There is no other difference between these machines. In my case, I knew I'd be driving across my lawn a great deal, so theoretically a larger contact patch would distribute the weight of the machine more. So far it's been great. The 424 is actually a rather unique machine, given its size, weight, and tire size combination.
/ 324 or 424?
Interesting. Can you explain the uniqueness a little more? Is it larger tractor capability in a smaller package? I did end up ordering a 424. Waiting a couple of more weeks for it to be delivered.
/ 324 or 424? #5
Yes, I may not have seen or tested everything on the market, but it seemed to be sized right between something like an LS XJ series on the small end, and a Kubota B2650 which is slightly larger. Seemed like the perfect fit for my property. The [rear] tire size is certainly something you won't find easily on tractors this size. Congrats on the order!! I think you'll be happy with this machine. You'll have to post a pic when it comes in!
/ 324 or 424?
Will do! I originally went with a 324 but after coming home and walking the property again and thinking more about what I wanted to use the tractor for I came up with plenty of instances where I would be going off improved surfaces and up and down rough hills. I live on a mountain on 9 acres with an old road that goes down into the holler. Making it down into the holler and back up the hill along with keeping a 1/2 mile gravel road running down the mountain in shape is going to be a challenge I think. May end up getting the tires loaded too but I'll give it shot as is. Thanks for the feedback! I'll be sure to post some pictures.
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2016 Deere 180G (A60462)
2016 Deere 180G...
Gehl RS5-19 (A62177)
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
