NX Loader able to curl and lift at the same time?
   / NX Loader able to curl and lift at the same time? #11
If time is a constraint then rent a construction-grade loader or skid-steer. If it's a patience issue then either learn to manage OR re-read my first sentence.
I've scooped and hauled a gawd-awful amount of material with my NX. I have zero issues operating it: and I've operated excavators and skid-steers. Loader action was the least of my time constraints: having to hitch and un-hitch my dump trailer and travel nearly 1/4 mile at a shot.
It's a feature constraint. If the MX series can do this, why would a NX not be so capable? The Kioti tech support person I spoke to said that the NX has this capability, but my experience on the test drive and comments on the forum would indicate that is not the case.
Are you using the standard NX bucket or have you upgraded to something larger?
   / NX Loader able to curl and lift at the same time? #13
I agree most all the other posters. You can get 2 functions to operate at once but you REALLY have to feather the joystick appropriately. After some seat time, you can get pretty efficient at it.
When you move the joystick to the full 2 function position, say full down and full left (lift up & curl back), you are essentially fully opening both valves, so which ever function needs less hydraulic demand (lift up OR curl back) is going to get priority and win until the demand of the other becomes less. Everything is a competition --- the other brand you mentioned will tout their ability to get 2 functions going at one time with a more complicated hydraulic pump. Kioti will tout their bigger lifting capacity. It's your choice which one is more important to you.
   / NX Loader able to curl and lift at the same time? #14
My CK4010 has the same slow response, a pretty big letdown after owning a skid steer for ten years.
I ended up buying a CTL for loader work. The tractor is pretty much relegated to snow blower work now.
Frankly, although I recognize that this is, first and foremost, a tractor site, I think a skid steer or CTL is a more useful tool, if you aren’t towing ground engaging implements.
   / NX Loader able to curl and lift at the same time? #15
Standard bucket.
Good luck on resolving your issues.
   / NX Loader able to curl and lift at the same time? #16
The loader valve is not piloted, so one function at a time unless really feathered.
Waendo, the Kioti support person doesn't know what they are talking about. The loader valve IS NOT PILOTED (LOOK THIS TERM UP SO YOU UNDERSTAND), so only ONE FUNCTION AT A TIME.
Thanks for the reply, makes sense.
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
2021 SAVANA 4500 BOX TRUCK (A57880)
2021 SAVANA 4500...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
