tractor [larger] sized metric nut and bolt assortment
/ tractor [larger] sized metric nut and bolt assortment #1
bryanhawaii
ford 1900
Just purchased a Japanese made Ford 1900 and replacing a lot of missing nuts and bolts and I am starting from scratch with a few American nuts but want to keep it consistently metric. I tried local sources and am now searching on-line sources for a handy assortment, but have only found smaller sizes . Can anyone suggest a reliable on-line source of tractor [larger] sized metric nut and bolt assortment , preferably with free shipping as I live in Hawaii??
Aloha and
Thanks in advance.............
/ tractor [larger] sized metric nut and bolt assortment #2
Aloha and
I know you said you looked locally but did you try commercial jobbers or actual fastener supply houses? I would imagine the larger cities would have such businesses. Even the small (non industrial) city I’m in has half a dozen dedicated fastener stores.
Good luck.
I'm in a small town on a small island in the Pacific and definitely not industrial so we have to import most things that you guys on the 'mainland' take for granted. but I will check for a fastener store here........................thanks for the tip.
/ tractor [larger] sized metric nut and bolt assortment #4
Fastenal is the largest volume brand.
/ tractor [larger] sized metric nut and bolt assortment #5
Just an FYI. On a Japenese
machine metric is not always the same as the rest of the world. There is a JIS standard that has different sizes and grades. Boltdepot.com has some good charts that show the differences. My Mitsubishi built Mahindra has ISO/DIN and JIS mix.
ANSI - American National Standards Institute
ISO - International Organization for Standardisation
DIN - Deutsches Institut f? Normung
JIS - Japanese Industrial Standard
* Indicates ISO standard.
/ tractor [larger] sized metric nut and bolt assortment #6
If your island has an Advance Auto Parts, try them for a metric assortment. It should take care of some of the smaller sizes. Around $10.00 if I remember correctly.
/ tractor [larger] sized metric nut and bolt assortment #7
The problem is that assortments tend to have every size you don't need and none of the sizes you do need. It would be a good idea to make an inventory of the required sizes and place an order with someone like Fastenal or McMaster-Carr for the necessary stock parts.
/ tractor [larger] sized metric nut and bolt assortment #8
/ tractor [larger] sized metric nut and bolt assortment #9
Gotta remember guys, the OP is in Hawaii.
/ tractor [larger] sized metric nut and bolt assortment #10
Needs to stop thinking "tractor" and start thinking "machinery" or "industrial"... His scope of search (tractor) is to narrow...
Dale
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
