Now that one wheel motor has failed, how likely the others will in short order?
   / Now that one wheel motor has failed, how likely the others will in short order?
Doomed. Let me know where you discard the machine. ;-)
Seriously, +1 to the seal and carry on... Put a spare on the shelf if your machine is mission critical. I find having a spare of something pretty well guarantees I'll never need THAT part!
Thanks guys. Really appreciate it. I AM purchasing a spare wheel motor, as having the rig down for 3 weeks is a real pain, right in the middle of summer!
Thanks again,
Rob :)
   / Now that one wheel motor has failed, how likely the others will in short order? #12
These motors are rated for 2000 hours (depending on bearing load and RPM). So, as a general rule, failures should be pretty rare.
Yowsa, I had no idea they were rated so high. That's terrific. I might never need the spare. On the other hand, it's often true that when you don't have one, then you need it (like I do now...)
LOL
Rob :)
   / Now that one wheel motor has failed, how likely the others will in short order? #14
LOL
Rob :)
It's kinda dry here.... i'm gonna go wash my car. ;)
   / Now that one wheel motor has failed, how likely the others will in short order? #15
I must have got a bad batch. Have replaced both front motors, 1st failed at around 850 hours and the other at about 1000. They do get a lot of stress though, as I frequently 3 wheel on hillsides. Trying to avoid that as much as possible by lifting the mower slightly when I see a wheel in the air.
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2015 New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
2015 New Holland...
2017 Ford F-350XL (A53314)
2017 Ford F-350XL...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
Year: 2001 Make: Dodge Model: Ram Pickup Vehicle Type: Pickup Truck Mileage: 30413 Plate: Body Ty... (A55852)
Year: 2001 Make...
