My New Kubota ZD1211 Mower
/ My New Kubota ZD1211 Mower #201
My grass around the farm gets way to tall & extremely thick to use a mulching kit.
I always mow at WOT to get the nicest cut :D
/ My New Kubota ZD1211 Mower #202
I’m thinking about removing the two loop skids from under rear of deck.
Owners manual says to remove them to reduce windrowing.
/ My New Kubota ZD1211 Mower #204
Two Bolt on brackets under rear of deck that acts as skids.
I’d guess 2.5” wide each
/ My New Kubota ZD1211 Mower #205
My ZD1211 throttle Cable had excessive slack not opening throttle wide open.
I adjusted cable to get WOT :D
/ My New Kubota ZD1211 Mower #206
Can you snap a photo of these?
I have been under the deck a few times, but not enough to remember seeing these
/ My New Kubota ZD1211 Mower #207
Pic is from Left Rear of my 72” RD deck :
IDK if SD decks have these or not ?
/ My New Kubota ZD1211 Mower #210
I looked at my deck yesterday and all I could see is the bolted on metal strip with rubber sweeper hanging down all the way across the back. I tried to feel if something like this was behind the flap on the very edge and couldn't find it. I'm thinking I'm going to remove the flap after trying machine myself (Grand used it last time) running at full throttle and evaluate results. $359 for Kubota mulching kit is a bit high but will do it if still getting that small row of cut clippings down the center.
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
2019 Deere 35G (A53317)
2019 Deere 35G...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
