   / Harbor Freight Tools that don't suck #11,471
I think it’s pretty decent for a beginner. All bench top lathes are lacking in stability. A beginner would be a lot better off with a cheap lathe and more sharpening equipment and accessories vs a better lathe without much else.
I think the problem, with the low end lathes, is they lack mass. A friend, firmly mounted his to a piece of 1/2" plate and that made a world of difference in stability and vibration.
   / Harbor Freight Tools that don't suck #11,472
Does anybody REALLY want a >>*white*<< tool cart?
I mean, unless you're running a clean room for some reason.
   / Harbor Freight Tools that don't suck #11,476
So Saturday I started the job of changing the timing belt on my daughter's Accord. All was going well until a water pump bolt broke. None of my tricks worked including welding a nut to what was left of the bolt. Of course there is very little space so off I went to HF to see what they have for right angle drills. All the electric ones are too big so I went with the attachment tool below because it has the shortest nose. The tool is actually built quite well, no loose bearings and the chuck is adequate. I pulled up a 20% off coupon on my phone plus grabbed a free tarp.
3/8 in. 9deg Angle Drill Attachment
   / Harbor Freight Tools that don't suck #11,478
Years ago when I managed to drive a 3 1/2 in framing nail thru 3 fingers with my nail gun, the ER Doc had to go to his car to get the right set of pliers for the extraction.
   / Harbor Freight Tools that don't suck #11,479
Ouch!!!
I carry needlenose pliers in my camping first aid kit, to cut off and extricate fishhooks out of the kids.
   / Harbor Freight Tools that don't suck #11,480
Yep nephew did that recently. Well actually his brother shot a nail and it hit a knot and ricocheted over and got him from about 8 feet away. At least it missed bone.
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
BIN PARTS, SWEEP AUGER & ELECTRIC MOTOR (A52708)
BIN PARTS, SWEEP...
WATER TRAILER (A58214)
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
