Tractor News NEW CK3510SE
/ NEW CK3510SE
I’m not going to have it delivered until around the 20th going on a cruise This Sunday to Sunday. So I told him to take his time. I would have rather skipped the cruise and get the tractor. But my wife and kids didn’t like that idea. I have no clue why. Lol as soon as I get it I will post pictures and I will keep you updated what I like and what it don’t. I was watching some you tube videos of guys making an enclosed removable cab. It looked really nice might be on my to do list. I let you know. Any questions just ask I’ll give you my honest opinion good or bad. Good luck. And thanks
/ NEW CK3510SE
I know I have been thinking about it and I keep making plans for doing more and more.
/ NEW CK3510SE #23
be prepared to work a lot more...
A tractor is supposed to SAVE time...but no, now that you can do all those things you've never even thought about you'll be working your a-- off! LOL
This is the most accurate post ever made on these forums.
I've had my tractor for a year...I'm just about due for my 150hr service. I've got a lot of work done in that time, but FFS, every time I cross a job off the list, I'm adding 3 more at the same time. It never ends.
/ NEW CK3510SE #24
I can relate, I will pick my 1705 up Saturday and my list has already grown and I haven’t even done the 1st item on the list.
/ NEW CK3510SE
That’s the way I am also I’m never happy and keep going and going. But I can’t wait to start getting jobs done to get my place in order. I have tons of brush needs to be moved. Roads and trails need to be cleaned up. I have a pond I want to clean out and make bigger and deeper. Also have to put in a bunch of water runoffs. I can keep going and going. But I can’t wait.
/ NEW CK3510SE #26
Ok received the itemized bill here it goes let me know if you think if I知 paying to much?
KIOTI CK3510SE WOTH IND TIRES
KIOTI FEL KL4030 WITH 60 INCH BUCKET
KIOTI KB2475L BACK HOE WITH 18 INCH BUCKET All three $29,999
KIOTI RC2060 BRUSH HOG $2,399
BEFCO BB2060 BOX SCRAPER $1,100
CKA162 3D FUNCTION VALVE WITH INSTALLATION $599.00
CKA165/CKA166 BACK HOE THUMB INSTALLED $350.00
LOADED TIRES INCLUDED
TITAN GRAPPLE 6- INCH $1,799
TAX $2,899.68
Total $39,145.68
It sounds about right. You could have probably shopped around for the attachments and saved a few bucks, but then you couldn't have rolled it into the loan. It's not enough that you will even remember it in 5 years.
Very nice tractor! I'm sure it will give you many years of service.
/ NEW CK3510SE
Yea I feel about average. Could have tried to shop around on attachments to save a few bucks. But I知 glad it痴 done. And will start to use it soon.
/ NEW CK3510SE #28
SGT3694 I’ve been looking very seriously at Kioti, mostly the CK2610 but I could easily be talked into a 35 horsepower machine. What is included in the SE model over the regular model that pushed you to buy the SE. I’ve looked at the brochures but I’m still a bit fuzzy on the exact content of the SE package.
/ NEW CK3510SE #29
tilt steering wheel, different pto - elec switch over manual lever and when raised it shuts off, instead of bolt type 3 point links they are telescoping pin types. And a tool box.
Plus some mix of link pedal, cruise, arm rest, rubber floor mat...I got these plus horn, mirror, loaded rear tires and rear remotes on my non-se for $700.
I got the 3510hst w/ loader and the above options for about 19,500 june 2018. I now have 325 hours on it.
only issues:
dealer installed rear remotes and once i started using them a gasket blew.
Front wheel rim bolts came loose about 80 hours - I did the 50 hours service and it said to torque them..I didn't do it. So not kioti's fault.
The extra HP is nice for hills and any PTO attachments - I got it mainly for mowing pastures (light duty brush hogging one might say), but have used it for all manner of things. I will be haying with it next month, running a new holland 276 baler.
/ NEW CK3510SE #30
The reason I went with the SE over the standard edition was because the SE does not have a clutch pedal or a clutch to maintain on the HST model. It had a tilt steering wheel, linked pedal & auto pto, . All of the options I was wanting were all ready installed on the tractor. I did not have to wait for the dealer to order & install the parts before delivery. Those options were dual rear remotes, rear view mirrors, rubber floor mat, telescoping draft links, dual element air cleaner, horn, cruise control & arm rests.
/ NEW CK3510SE #31
If I may be so bold as to ask , what was the difference in cost between your SE and the regular 3510? I知 being quoted 19600 for a 2610 in New Hampshire
/ NEW CK3510SE #32
The cash price on my CK3510SE HST was $21,500. I did not price the regular version because my dealer did not have one on the lot.
/ NEW CK3510SE #33
That seems like a pretty reasonable price increase for what I think is a lot more tractor than the 2610!
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
INGERSOLL RAND SSR-2000-EP150 AIR COMPRESSOR (A64280)
INGERSOLL RAND...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
