Massey 205 stalling after running
/ Massey 205 stalling after running #1
Ruff3307
1982 Massey Ferguson 205-4
Hello all;
Well I hope someone on here can provide me with some direction.
I have a 1982 Massey Ferguson 205-4. It runs a Toyosha 2 cylinder diesel with approx 3,000 hours.
Here's the problem, The tractor starts great, quickly and generally with only a short time using glow plugs. After running / working for 30-45 minutes it acts like it's running out of fuel, you can throttle up a bit and it will keep running but within a few minutes it will continue to slow and then stall. It will not restart, leave it for a while, less than an hour and it will restart but it happens again after a short period, leave it for longer, over night for example, and it starts and runs great for that same 30-45 minutes.
I have replaced the fuel lines, fuel filter and checked for obstructions in the tank. Flow is good to the injection pump and the gas cap is venting properly. I have run it without the cap and it still happens. Also changed the oil and filter.
Any ideas or experience with this?
Thank you
Mark
/ Massey 205 stalling after running #2
IF your fuel filter set-up is a 3 pc. unit, w/ a long screw in the center that holds everything together..??
Check & MAKE SURE the top oring that seals the filter is UP "IN" the groove on filter HEAD.. NOT "ON" the filter..
IF u put it ON the filter, it chokes off the fuel & does exactly as u described..
Good luck.
Thank you for the reply
No it has a 1 piece filter, screw on type like the oil filter.
/ Massey 205 stalling after running #4
It was worth a shot..
Is it "gravity" fed or does it have a supply pump.??
Is there a filter screen on the fuel tank OUTLET.??
Do u have access to a torque wrench & sockets.??
No fuel pump so I assume gravity fed
No filter screen at tank, there is one at the shut off but that has been checked.
Yes I have a torque wrench.
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
1975 Bomag MPH1 Soil Reclaimer Mixer (A61572)
1975 Bomag MPH1...
More info coming soon (A61574)
More info coming...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
