Tractor suggestions for primarily snowblowing a long, steep, windy driveway?
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #11
I found a JD 4100 with cab and 47" snowblower for $9k. Do you think that is a good deal and enough to get the job done.
Seems like an ok deal. How many hours on tractor? Is it a front mount? The JD is similar in size to my B7800, just a little less hp. It all comes down to how much you are willing to part with. The cab will really make your life easier. I always came back like a frozen icicle. Does the cab have heat and A/C? In the summer a cab without A/C can be tough. You are in a 'greenhouse' and it gets hot really fast. You can probably move more snow with that JD than with a bigger tractor that you push snow with.
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #13
i smell trouble right away, you are going to be disappointed in the traction of a tractor vs the gator getting back up the hill. You will likely need chains just FYI. A tractor with most any tire is helpless on snow pack/ice. The tires are even more stiff and worse traction when cold. It wont matter what kind you have Ag/R4/Turf they will all be challenging on traction.
I don't know, the HDAP tires on something like an x7-series Deere garden tractor do really well in snow & ice, even on sloped driveways. I have a buddy with an x728 and what I consider a fairly steep driveway (maybe not as much as the OP's) and he has never needed chains. You can certainly add chains to such a tractor. And, of course, get the AWD version (x728/x748 or x738/x758). Load it up with ballast, of course.
I've never used a Gator with a plow but I find it hard to comprehend that a Gator would be that much better than a x7-series JD.
Rob
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #14
My dad uses a x749 with a blade on a drive that has a off camber slanted part....just weights and 4x4.
It has 281 hours and it is a front mount. The cab has no conditioning but removable doors.
That's a 70% grade - sounds frightening!
Any pictures?
Yep, you nailed it. Here's a picture. I have realized it is impossible to capture hills with cell phone cameras
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #17
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #18
That's low hours. The cab will make it worthwhile in winter.
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #19
Does it have a loader? That is my highest used attachment. If it doesn't, maybe price one out. I remember looking at tractors and thought I found a good deal, except it did not have a loader.
R4 tires loaded for ballast. No loader. I'm sure it is useful but I can't even think of a use for one. I live in the burbs with a small yard. Just trying to solve the driveway issue in the winter.
QA Hitch Plate (A56469)
QA Hitch Plate...
6 HITACHI WEDGEDOCK COUPLER (A57192)
6 HITACHI...
UNUSED FUTURE HYD AUGER SET (A57193)
UNUSED FUTURE HYD...
2020 JOHN DEERE 245G LC EXCAVATOR (A52707)
2020 JOHN DEERE...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
PALLET OF HYD HOSES (A57192)
PALLET OF HYD...
