Having a blast with our new M62
   / Having a blast with our new M62 #211
Carrying dirt with a loader bucket is about the slowest way to move dirt,
around here when they are digging a pond the most common is an excavator and a dozer,
the excavator is digging and dumping,the dozer is pushing and spreading the spoils where it's wanted.
   / Having a blast with our new M62 #212
The big thing I've found about dirt moving projects is that most of the time is spent doing just that: moving dirt away..... running back and forth with loader buckets full of dirt. I wonder if a dumptruck adds time or not? Guess it depends entirely on how far the dirt is to be moved. Also if there is a place to put it. Around here, good dirt is easy to dispose of. Everyone around here can use good fill dirt.
rScotty
It makes a big difference in how far your going. With only one operator a truck isn’t a huge advantage unless you’re going a long ways. Having 2 operators the truck makes a huge difference.
Oh, man. That sounds like the same kind of failure I've seen already on my L3240. Maybe Kubota hasn't learned how to build a stout enough front axle yet? It's only been 14 years since my '05 was built.:confused2:
Yep, that's the one. ONLY six days? You're a regular busy beaver! Even if it took me twice that long, I'd still tackle it. Being retired, It's not about wages, but what it would cost to have someone else do it (if I could even find someone to actually do it right) vs. what else I should be doing with my time. And you make it look so easy!
That's the same ballpark I'm seeing now. I've heard some folks get the dealer to come off suggested retail by 15%, but I'm only seeing half that.
Are you happy with the traction with the R4 tires? I'm gettin' nuthin' but a runaround from the local dealer and Kubota corporate on fitting R1s for better traction on my 20%+ hillsides.
As an aside, I was late to dinner tonight because I was helping a neighbor repair the torn up loader arms on his Cat backhoe. They'd failed in exactly the same way as those on my LA724 Kubota loader, circumferential cracks around the stiffener tube welds between the two arms. But now he wants to repair another failed set of arms, this one had a pin back out on the forward end with a full bucket, which broke the weld holding the opposite pin housing and slightly twisting the arm. But at least the pivots were bushed, so once we cut the housing off the arm and weld it back in place, we can clean up the weld distortion in the housing and get a bushing back in so it'll work again. That is until the stiffener tube welds crack.:eek:
I guess you names yer poison and takes yer chance...
Traction good as is for me. We live in the sand so unless you are a 100hp or so the r1s are not wide enough and to aggressive making them bury themselves fast.
I agree. Or using a dump truck. Depending on size Ive seen them use a scraper / earth mover and dozer.
You are for sure correct. I am always a one man show. This is why I dont have a large mini excavator and skid steer. I just use the M62 so I can do it all by my lonesome.
   / Having a blast with our new M62 #218
Interesting. Where did you install it at?
Accumulator has installed by dealer maybe 13 years ago, precharged to 2000 Psi with Nitrogen. I will try getting a photo at some point to show Location
   / Having a blast with our new M62 #219
You are correct on moving the dirt. Half the time was probably hauling and pushing the dirt that came out of that hole.
It seems that fame could have been used to make a trailer or something. :scratchchin: :scratchchin:
Thanx. Very curious.
Rooster Weathervane (A55853)
Rooster...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2013 Ford F150 (A55973)
2013 Ford F150...
Golf Cart (A55787)
Golf Cart (A55787)
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
