Start Lawn Care In August?
/ Start Lawn Care In August? #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
Hello Everybody,
In April I reseeded some areas of the lawn and did nothing else. The areas have now grown, and the yard in general looks kind of rough. I mow and trim but what I mean is there is clover, crabgrass, gone-by dandelions, and other weeds. So, can I apply a weed and feed now? I know the weeds die off in the fall but this might give me a jump start.
Oh, almost forgot. I have a blueberry patch with 300 plants. Is it safe to apply weed and feed in that area too? I prefer granular rather than liquid.
/ Start Lawn Care In August? #2
You can weed and feed a few times a year, I generally do it 3-4 times a year on my commercial property. Your seed has been established long enough to hit it with some as well.
I would figure out what fert you are using then check with the bushes. Most are sorta okay for trees and bushes and a little wouldn't hurt them, but hitting them with a lot of it might be bad depending on what you use. Since you are using granular, maybe find a spreader with an edge guard that will stop it from spreading all over bushes.
I just learned about edge guards on spreaders. My blueberry bushes are 7 feet apart in rows that are 10 feet apart so it will be hard to do. Blueberry bushes have very shallow roots too.
/ Start Lawn Care In August? #4
there is an option to use drop spreader. Scotts Turf Builder Classic Drop Spreader
/ Start Lawn Care In August? #5
i know my dads bushes he hits with some nitrogen heavy stuff. A lot of organic grass fertilizers are mainly nitrogen boosts, might be able to talk to a local company and find one that would benefit both, or at least not hurt the bush.
@suburbanfarmer has a good idea with the drop spreader too.
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New Idea 5409 Disc Mower (A66408)
New Idea 5409 Disc...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
