which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s
   / which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s #121
better call the manufacturer of every payloader and let them know.
That’s the same way my backhoe is. I don’t like the cylinder mounting because it sticks up in the air, but there’s no difference in strength. Duel cylinder are plumbed in parallel and do nothing to help the frame from twisting. Btw the wheel loaders do that to reverse the direction of the cylinder to curl the bucket up with the extension stroke which is stronger. Most other loaders with a cylinder cylinder still curl up with the retraction stroke.
   / which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s #122
I had a lemony 1025R for almost 2 years between good 4010 and 2025R. Cannot recommend the 1025R.
Ralph
What year was it? What didn稚 you like about it?
   / which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s #123
Look it up, I believe they had a lot of problems with this model, especially the aluminum rear.
   / which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s #124
What is this aluminum rear problem I hear people talk about? I know several people with 2305, 1025, 1026 never had rear end trouble..
   / which one, JD 1025R or MF GC1720 or MF 1526 with woods backhoe or NH25s #125
Breaking . . . iron is your friend.
That痴 the same way my backhoe is. I don稚 like the cylinder mounting because it sticks up in the air, but there痴 no difference in strength. Duel cylinder are plumbed in parallel and do nothing to help the frame from twisting. Btw the wheel loaders do that to reverse the direction of the cylinder to curl the bucket up with the extension stroke which is stronger. Most other loaders with a cylinder cylinder still curl up with the retraction stroke.
Twin cylinders give much better load control than a single cylinder. A single cylinder is just manufacturer cost cutting in lower priced units.
2014 Aerway Aerator (A55973)
2014 Aerway...
New/Unused Agrotk Wood Splitter (A57453)
New/Unused Agrotk...
Meyer 8.5' Snow Plow w/ Bracket (A55272)
Meyer 8.5' Snow...
PALLET TOTE OF MISC CATCH PANS & HEATER PARTS (A58374)
PALLET TOTE OF...
2017 MACK  CXU613T (A58214)
2017 MACK CXU613T...
PROTEMP 175,000 BTU HEATER (A52708)
PROTEMP 175,000...
