   / Harbor Freight Tools that don't suck #11,401
yeah guaranteed 20% coupons anytime. But the 30% are rare and I don't see them on this site.
The 30% coupon was on that site a week ago. But with a $10 max for regular price, it's really limited in my opinion. It gets your attention until you realize you can save 'up to' $3.00.
   / Harbor Freight Tools that don't suck #11,402
Saturday I used a harbor freight 4.5 angle grinder to grind the weld off my exhaust pipe to get a new muffler on my car.
   / Harbor Freight Tools that don't suck #11,403
The 30% coupon was on that site a week ago. But with a $10 max for regular price, it's really limited in my opinion. It gets your attention until you realize you can save 'up to' 30 cents.
30% off a $10 item is $3.00, not $.30.
   / Harbor Freight Tools that don't suck #11,404
Ha, that was a brain typo - thanks. I corrected it. But I meant $3.00 compared to the everyday $2.00 or $2.50 discount on the same items isn't worth a special trip. Plus the normal coupons don't have a $10 product limit.
   / Harbor Freight Tools that don't suck #11,405
I know I could research this thread but I am lazy. Looking for experience on HF Gantry Crane.
Telescoping Gantry Crane - 1 Ton
Looking to lift off my F-150 bed for a repair. Thoughts? Thinking of using a 25% coupon. Puts it at $555 plus tax. Seems worth it. Problem is I have no more room in my garage/shop.
   / Harbor Freight Tools that don't suck #11,406
Overkill.
A bed lift frame and an engine hoist will do the same cheaper and better.
And won't take up much room when you store it.
   / Harbor Freight Tools that don't suck #11,407
For doing that, the engine crane is more than enough and takes up way less space... Last time I pulled the bed on my Ranger I took 4 2x4's (scraps) and screwed them in pairs to a length that would fit under the bed rails then just put a chain in the mix and lifted the bed, on an F150 it's probably around 400lb tops but whatever I did 3 years ago on the Ranger worked very well and was simple...
Not to push you against the A frame, as I plan to buy one or make something similar once I get my shop built...
   / Harbor Freight Tools that don't suck #11,408
Set some pallets or sawhorses behind it to keep it at the same height and pull it by hand. 2 stout guys can do it or with 4 people it’s a breeze. Or just use your tractor.
   / Harbor Freight Tools that don't suck #11,409
Gantry crane has worked well for me but I replaced the I-beam with a higher rated one that I had.
   / Harbor Freight Tools that don't suck #11,410
So dragging the bed aft will be a piece of cake and not damage the bed? Still like to be able to lift things. Always fighting heavy loads and with age, I am losing.
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2018 Ford F-550 Altec AT48S 48ft Material Handling Bucket Truck (A55973)
2018 Ford F-550...
Wanco Message Board (A56857)
Wanco Message...
22167 (A56859)
22167 (A56859)
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
