sickle bar mowers....pain in the *** to hook up and take off
   / sickle bar mowers....pain in the *** to hook up and take off #1
Little General
Mi. Pleasant , N/C/
Kubota M7060 w cab Kubota x1100c Kubota KX008 John Deere 4400 , JD TLB110
Is it just me ? Hooking up my sickle mower was a pain but taking it off was worse. The dang thing is just cumbersome and needs a cradle to sit in. Maybe I was just having one of those days or am I ?
   / sickle bar mowers....pain in the *** to hook up and take off #2
Is your sickle bar integral on the right side or is it a three point hitch model?
You need level ground and wooden blocks to help in mounting it.
   / sickle bar mowers....pain in the *** to hook up and take off #3
So build a cradle for it to rest on.
All of my implements have wheeled cradles/pallets for ease of mounting/dismounting for both the FEL and 3PH. Some are custom built, by me, to accommodate the idiosyncrasies of the individual implement to have it in the correct orientation (height & angle) to accomplish this.
   / sickle bar mowers....pain in the *** to hook up and take off #4
My case IH 1300 is pretty simple, I do use a quick hitch.
   / sickle bar mowers....pain in the *** to hook up and take off #5
Once when investigating what sickle mower mower to buy, a dealer said to avoid such and such a make. It was nicknamed the "family" mower as it took the whole family to attach it. I don't remember the brand.
   / sickle bar mowers....pain in the *** to hook up and take off #6
As others have said, build a stand or get a couple of large pallets for the mower to rest on. The pallets need to be sufficiently long to support the entire length of the mower. But if it is several inches off the ground then it is easier to connect. Without knowing the type of mower you have, some are definitely harder to connect than others. I have a 60 year old IH 100 similar to the 1300 mentioned above. W. Jones
   / sickle bar mowers....pain in the *** to hook up and take off #7
I recently bought a 9’ NH 451. I got it hitched up and tried it out ... it’s great for mowing around our lake. I haven’t attempted to remove it yet, so I appreciate the warning! The skids which should hold it up when dismounted are too beat up to work, so I’ll try to figure out what sort of cradle I need to build for it.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
Yamaha (A55758)
Yamaha (A55758)
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
