Telescoping pipe
/ Telescoping pipe #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I seldom have trouble finding square tubing that will telescope but the black iron pipe at Lowes won't fit into the next size up and the size above that is a very loose fit. The problem isn't an inside seam on the outside pipe. The inside diameter of the outside pipe is just too small. What do you guys do when you want round pipe that will telescope with a nice fit?
/ Telescoping pipe #3
Most steel houses have a chart that will assist with round, square and rectangle tubing sizing for what you want to do. Wall thickness might not all be exactly the same though.
/ Telescoping pipe #4
Just do a google search for pipe dimensions. There are several charts available (one from Saginaw Steel) that list all the variables in pipe ID, OD and wall thicknesses.
Tubing will likely be easier to match up with a specimen that will fit inside of another one. Piping has a few that will, 1.5" inside a 2" comes to mind but you have to get the schedule (thickness) right for this to happen. Matching up pipe OD's to fit the ID of another one is a bit time consuming when looking at the data.
/ Telescoping pipe #5
most box stores carry schedule 40 one could try schedule 80, which is thicker and could take some of the slop out of the fit,
/ Telescoping pipe #6
There is a difference between pipe and tubing. Pipe has a minimum wall thickness but is allowed to vary a little. Tubing has a much more consistent wall thickness. If you are going to telescope the tubing, you should check out DOM (drawn over mandrel) tubing. It is very consistent and you can get different sizes with different wall thicknesses.
/ Telescoping pipe
Thanks everyone. Your responses came in in a flash and gave me plenty of information to work with. I'll check what my supply house has when I'm out there. They finally got smart and put out samples. I was trying to go through Lowes because I didn't need much and the supply house won't sell less than a stick.
/ Telescoping pipe #8
For a good telescoping fit I use DOM (drawn over mandrel) tubing which has the inside flash weld removed. Typically the inside diameter of the larger tube would be .010”larger than the outside diameter of the smaller tube for a nice sliding fit.
Here is an example of DOM tube I used for removable handles on a cart I made.
Edit: 3Ts gave same suggestion while I was typing.
/ Telescoping pipe
Nice work Big Barn. My work is crude compared to yours.
/ Telescoping pipe #10
How much do you need? How strong do you want it?
Some ideas....
A big-stick CB base antenna is telescoping.
Some flag poles are also telescoping.
2007 International Derrick Digger (A60352)
2007 International...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
Deere 333G (A53317)
Deere 333G (A53317)
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
